Author Topic: Would you guys trust this...possibly with your life?  (Read 1727 times)
Jeff AMN
    • Gamer Theory
« on: June 01, 2007, 01:50:08 pm »
I have a Donkey Kong cabinet that I'm restoring and I need to do a cap kit replacement on the monitor. I've never worked on monitors before, so this will all be a learning experience. Now, I don't have any tools to discharge the monitor, but I was wondering if you guys would trust this tool (which I do have) to tell me whether or not the monitor is holding a charge.
I picked one up from Home Depot for another project a while back, and it works well. It beeps and flashes if there is any voltage present. I've plugged the DK in, got it close to the monitor's no-no area, and it lit up. It even lit up after unplugging the machine for a while. However, just the other day it didn't light up. Do you guys think I can safely assume that the monitor has discharged? Would you trust it?
shardian
Re: Would you guys trust this...possibly with your life?
« Reply #1 on: June 01, 2007, 01:56:23 pm »
Short answer, no. Even with a bleed resistor, there could still be enough residual charge to give you a comfy tickle. Always thoroughly discharge a monitor before messing with the electronics.
« Reply #2 on: June 01, 2007, 01:57:50 pm »
Long answer, ---fudgesicle--- no.
If you can't be confident in your ability to discharge the monitor don't touch it.  You're not ready to do the job.
BobA
  • What Me Worry?
« Reply #3 on: June 01, 2007, 02:08:08 pm »
That tool detects AC voltage.   The charge on a monitor is DC and would not be detected.
Always discharge a monitor even if you think it has been discharged.  Be safe not SORRY.
northerngames
  • Trade Count: (+18)
« Reply #4 on: June 01, 2007, 02:27:46 pm »
http://www.arcadegames.net/sightsound/discharge.ppt
this is a simple way to do it with common tools
« Reply #5 on: June 01, 2007, 02:56:56 pm »
That's not a bad tutorial.  I'd add a couple things, like making sure not to scrape off paint around the anode, and use a more insulated screwdriver than that.
Jeff AMN
    • Gamer Theory
« Reply #6 on: June 01, 2007, 04:47:25 pm »
Ok, thanks guys.
I'm confident enough in learning how to discharge and doing it, I just wanted to know if I could trust that thing to avoid having to learn.
shardian
« Reply #7 on: June 01, 2007, 04:57:05 pm »
It is still a very handy tool when doing household electrical work.
northerngames
« Reply #8 on: June 01, 2007, 08:23:59 pm »
I pulled the link from the monitor FAQ by menace but yeah I was thinking the same thing with the screw driver shown I have the exact same one and don't think I would try it with that type just to be sure I would suggest one with a rubber casing over the handle or if you do use a screw driver like that at least were a rubber glove I never been shocked by one and hopefully never do lol.
