Author Topic: cheapest minimum material?  (Read 3840 times)
dndcollect
  • Last login:September 18, 2007, 09:09:54 pm
« on: June 01, 2007, 01:00:38 pm »
someone here gave me a great idea for like a test cab, by using insulation paneling. it works great.
however its very delicate and can only be used for tests, etc.
so i was wondering, what is the bare minimum material that can be used? i know that Midway made those Target cabs out of particle board right?
the reason i ask is because i want to build something quick and cheap for this little kid that comes over from time to time.
is there any material that you can think of that i can build one out of that fits this idea?
styrafoam maybe? LOL, j/k
shardian
Re: cheapest minimum material?
« Reply #1 on: June 01, 2007, 01:59:19 pm »
Particle board is fairly cheap. Low grade subfloor plywood/ chipboard would maybe work for a rough cabinet. To tell the truth though, MDF is not all that expensive and gives you a very nice finish.
SavannahLion
« Reply #2 on: June 01, 2007, 02:47:50 pm »
Is scratchbuilding the only option for you? With care, you can find gutted cabs for really cheap, or even free, that you can easily turn into MAME machines. Also, short of a total restore or an extensive control conversion, it's probably faster to reach a finished stage because you already have the completed cab.
dndcollect
« Reply #3 on: June 01, 2007, 04:10:43 pm »
for me, yeah i would do that. actully i am in the process of building 2 bartops for myself those i am using wood, etc.
im just exploring what other matertial can be used if i want to make a cheap, almost throw away cab.
i acknowedlge that the idea to some is ludicrus.  :laugh:
« Reply #4 on: June 01, 2007, 04:12:10 pm »
You use an Xbox and a TV.
TOK
  • The Game Always Wins
« Reply #5 on: June 01, 2007, 04:55:32 pm »
Most alternate materials cost more than a sheet of MDF. Instead of making something cheap that he can ruin, why not make something cheap that he can't possibly ruin?
That is part of the appeal of real arcade controls to me -they'll stand up to a lot of abuse.
ScottS
  • Last login:November 01, 2007, 02:21:30 pm
« Reply #6 on: June 02, 2007, 01:42:55 pm »
Why bother asking us? Go down to your local Home Depot or lumber yard and see what sheet goods they have and what the prices are. Particle Board, MDF, Oriented-Strand Board (OSB), CDX plywood, just about anything can work... Heck, if you want super-cheap, build a frame out of some 2x4s, glue, and screws, then skin it with whatever 1/4" sheet good you can find. You'd probably need a small piece of 3/4" material for the control panel top. If you can wait a couple of weeks (or months) for the 2x4s to dry, you'll have better results.
dndcollect
« Reply #7 on: June 02, 2007, 02:24:54 pm »
ok my fault.
shardian
« Reply #8 on: June 04, 2007, 09:14:30 am »
Cover the frame with drywall, that way when you get pissed after losing you can put a whole thru the machine...then you can repair it real easy! ;D :laugh2:
« Reply #9 on: June 04, 2007, 09:36:20 am »
Build a frame out of 2x4s and wrap a curtain around it.
knave
  • Last login:October 15, 2025, 04:12:19 pm
« Reply #10 on: June 04, 2007, 12:28:06 pm »
You could use carboard.
BobA
  • What Me Worry?
« Reply #11 on: June 04, 2007, 12:44:44 pm »
You can make furniture or a cab from free fedex shipping boxes.
« Reply #12 on: June 04, 2007, 12:45:53 pm »
That looks like it took so much work you may as well get a job and buy it.
