Author Topic: can the mounting bracket be taken off the betson 27"  (Read 1486 times)
scurvy
  • Last login:July 23, 2008, 11:31:43 pm
« on: May 29, 2007, 03:50:41 pm »
from what i've been reading the betson 27" is 24.5" wide with the bracket, but the actual monitor is just under 23.5"
24.5 is too wide and will not fit in my cab, but 23.5 will fit in my cab.. so i'm wondering if i can take the mounting bracket off and somehow secure it into the cab another way.
shorthair
Re: can the mounting bracket be taken off the betson 27"
« Reply #1 on: May 29, 2007, 05:14:32 pm »
They're welded on.
Joystick Jerk
  • Last login:June 26, 2024, 05:10:33 pm
  • Slave to the stick.
« Reply #2 on: May 29, 2007, 08:14:03 pm »
How wide is your cab? If the difference is small, you could always get an angle grinder and grind a bit of the edge off the mounting bracket.
scurvy
« Reply #3 on: May 29, 2007, 08:33:49 pm »
the space inside the cab wall to wall is 24"
Joystick Jerk
« Reply #4 on: May 29, 2007, 11:40:00 pm »
Hell yeah you could grind off a tad more than a half an inch.
scurvy
« Reply #5 on: May 30, 2007, 12:07:14 am »
 :D
thanks for giving me hope! we'll see in a couple days.
