Author Topic: UltraStik 360 New Feature Release: Shift Function  (Read 11578 times)
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« on: May 26, 2007, 09:28:26 am »
The UltraStik 360 now has an optional shift function.
In addition to the usual 8 buttons which can be connected to each stick, there are now a further 7 "virtual buttons".
Holding down button 8 (which still has its usual functionality) and then pressing any other button activates one of the 7 virtual buttons.
So, for example, you could assign button 9 in MAME as "coin". Then holding button 8 and pressing button 1 would generate the coin button.
Button 8 can be used either as a dedicated shift button (by simply not assigning any function to it) or used as a normal button.
This feature is contained in new firmware 2.4 which can be downloaded to any UltraStik 360s. Full details at the foot of the page:
http://www.ultimarc.com/ultrastik_inst.html
This shift functionality can be enabled, optionally, by downloading this firmware. If you don't want this function, just continue to use 2.3. Sticks will ship with 2.3 (shift disabled) for now, but based on user feedback we might switch the default to 2.4.
Andy
Chris G
Re: UltraStik 360 New Feature Release: Shift Function
« Reply #1 on: May 26, 2007, 01:19:20 pm »
Great addition - thanks Andy!
rockin_rick
  • Last login:May 27, 2017, 09:20:20 am
« Reply #2 on: May 26, 2007, 01:24:00 pm »
Thanks for continuously improving these and for making the updates free.  (and for making the path to upgrade free during the design phase (aka flashable rom))
If I do not respond to your post in a timely manner, feel free to PM me.
Donkey_Kong
    • CNC Machines
« Reply #3 on: May 26, 2007, 01:50:44 pm »
That is friggin' awesome!  :notworthy:
AndyWarne
    • Ultimarc
« Reply #4 on: May 27, 2007, 04:10:21 am »
I forgot to mention that this new version also includes the mouse emulation mode, which is now standard, enabling the joystick to control the mouse pointer. This can also emulate a trackball.
Andy
loadman
  • Last login:January 29, 2026, 07:18:10 pm
    • MaLa
« Reply #5 on: May 27, 2007, 05:52:50 am »
Andy
Now that is a good idea...
I think I have run out of excuses for talking the wife into a purchase  ;D
fatfingers
  • Got UltraStiks?™
« Reply #6 on: May 27, 2007, 11:32:46 am »
If I'm hearing this correctly, this means there is probably no need for an encoder now?!  Before the 8 buttons didn't seem to be enough with 7 buttons per player (plus a p1 start, p1 coin up, etc).  But, with 7 other shifted functions...
So, am I hearing this correctly???
If so, three cheers for Andy!!!
Edit:  Was anyone else able to download the 2.4 firmware?  The link I see on the ultimarc site does not seem to work.
« Last Edit: May 27, 2007, 11:40:34 am by fatfingers »
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
Donkey_Kong
    • CNC Machines
« Reply #7 on: May 27, 2007, 01:12:19 pm »
I was able to download the firmware by right clicking and saving. Left click was a dead link.
fatfingers
  • Got UltraStiks?™
« Reply #8 on: May 27, 2007, 01:45:18 pm »
Hmmmm...that doesn't make much sense to me.  Regardless, I tried that as well, but still no luck.   :(
Thanks.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
AndyWarne
    • Ultimarc
« Reply #9 on: May 28, 2007, 04:52:15 am »
There was a slight "case-sensitivity issue" with the link, now corrected.
Andy
fatfingers
  • Got UltraStiks?™
« Reply #10 on: May 28, 2007, 07:45:07 am »
Andy
Thanks Andy!  Works now!
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
destructor
« Reply #11 on: May 28, 2007, 11:27:53 am »
Andy
Andy, with old firmwares I can use button 8 (or other button) as "shift" button too in MAME. I can simply hit TAB during game and define (example):
- coin - button8 AND button1
- p1 start - button8 AND button2
I can use button7 as second "shift" button too. button6 as third "shift" button. Button5 ....
I can use every button as "shift". Each mapped button works as single button too. No special shift button is required for it.
Where is difference between this method mapping buttons on old firmwares and new firmware 2.4 shift button?
AndyWarne
    • Ultimarc
« Reply #12 on: May 29, 2007, 08:23:11 am »
Yes you can do it that way. Mame has a built-in shift function in effect. Just another way of doing it.
« Reply #13 on: May 29, 2007, 10:30:19 am »
This is so freaking sweet.  I'm wiring a coin door but I'm out of buttons (3 action, 1P start, 2P start, pause, ESC, and coin door) and now I can use the shift function to input a coin virtually by holding down pause and hitting 1P start.  I was going to have to keep inserting coins in order to keep playing which is fine and dandy for limiting my daughter's play time but not so great when I want to play a ton of games in a row.  I can't wait to try this out!!
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #14 on: May 29, 2007, 12:10:16 pm »
...Where is difference between this method mapping buttons on old firmwares and new firmware 2.4 shift button?
Mame only vs any emulator, game, or application.
Robin
Knowledge is Power
krazy_kenny1
  • Last login:May 20, 2011, 11:14:32 am
« Reply #15 on: May 29, 2007, 03:18:06 pm »
How hard would it be to make it where you could enable or disable the shift function and the mouse emulation from the software...even on a per-stick basis?
stephenp1983
  • Last login:March 24, 2024, 11:26:39 am
« Reply #16 on: May 29, 2007, 03:43:54 pm »
I sent you a pm about this, but thought I'd post the question as well.  I believe someone else asked this but it doesn't look like it was answered yet.  So with the ultra stick we can hook up 8 buttons and have 7 or so virtual buttons as well.  This would mean there would be no need for an encoder correct as long as we were just doing a simple control panel?
destructor
« Reply #17 on: May 30, 2007, 02:41:50 am »
Encoder will be useless for joystick games. But for games without joystick support where buttons are defined as keyboard letter and directions as arrow keys you must have encoder still.
stephenp1983
« Reply #18 on: May 30, 2007, 01:00:39 pm »
So I assume it would work find in Mame then, just not some other emulators?
krazy_kenny1
« Reply #19 on: May 30, 2007, 03:38:31 pm »
Since windows detects it as a gamepad/joystick, it should work with any emulator that can recognize a USB plug-and-play joystick I would think.
AndyWarne
    • Ultimarc
« Reply #20 on: May 30, 2007, 06:59:03 pm »
The mouse function can already be enabled/disabled on a per-stick basis. Enabling the mouse function is done by downloading a special map. Maps can be downloaded to each stick.
You can enable the shift function on a per-stick basis by changing the firmware but I am not sure there is much advantage in having this changed by any other method.
Andy
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #21 on: May 30, 2007, 10:41:21 pm »
The point of adding the shift function to the Ultrastick is that now shifted inputs will work with other emulators.  And non-emulator PC games, and whatever other software you care to use.
Destructor's point is that this doesn't help with games that'll only accept keyboard commands for movement.  Which really only applies to pre-1991 or so games, and only some of those.  If you do have such a game, you'll still need a keyboard encoder- otherwise, nope.
Jouster
  • Flap, Flap...Crash
« Reply #22 on: July 04, 2007, 12:58:30 pm »
I don't come to the forums for a couple of months and look what I miss.
Am I on the right track with the wiring diagram below to make 14 dedicated buttons?
Jouster
[Edit] - The pic didn't look as good when linked...try below.
« Reply #23 on: July 04, 2007, 01:04:20 pm »
Jouster
Did he say dedicated 14 buttons? I thought it was 8 dedicated and 7 shift/virtual buttons
Donkey_Kong
    • CNC Machines
« Reply #24 on: July 04, 2007, 01:45:57 pm »
It is exactly what he said. If you really want your U360 to perform all of that, you might want to make the virtual buttons do your administrative duties. It might suck to hold down a shift key while playing pinball. Even though the shift key on this is awesome, you might still want to look into an Ipac...you have a lot going on there.
Jouster
« Reply #25 on: July 04, 2007, 02:01:25 pm »
Ok, then maybe I'm not on the right track.
I thought that could use the 7 dedicated pins for their buttons by only being connected to the ground wire, and the numbered pin. (normal button setup)
Then I thought I could use the other 7 buttons by connecting them to both the 8th pin (shift) and a numbered pin 1-7 plus the ground.  These buttons would basically be sending button 8(shift) + the other pin.  I was thinking that this would eliminate the need for an actual 8th button to be used as shift.
The buttons would correspond to pins 1-7 individually, then 8&1, 8&2, 8&3...etc to 8&7...for 14 buttons total.
Maybe I'm not explaining it clear enough?
Jouster
Kaytrim
  • I'm too nice a guy
« Reply #26 on: July 04, 2007, 02:09:01 pm »
Jouster
I think you have it right.  The only way to be sure is to test it out.  Randy's Shazam button can work that way but he has some special wiring harnes.  It includes diodes but I am not sure what the purpose is.  Here is a link to the special diagrams for the KeyWiz  I am guessing that you would need to use a simular wiring setup for your plan.
AndyWarne
    • Ultimarc
« Reply #27 on: July 04, 2007, 03:17:44 pm »
Jouster
Er.. no. If you think about it, and look at your diagrams, what you have done is connected all the pins together which is definitely not what you want to do! There is a path from each pin, via the shift pin to every other pin.
This kind of arrangement can be made to work actually but you do need to use diodes and its probably not worth the hassle, but if you want to have a go, drop me an email and I'll help.
andy@ultimarc.com
