Author Topic: Chassis ID help please  (Read 2109 times)
Angry_Radish
  • Last login:October 24, 2020, 06:36:17 pm
« on: May 25, 2007, 10:34:04 am »
Hi all,
I recently picked up a space tactics cab, and while I'm repairing the main board, I thought I would try to track down the manual for my monitor incase that doesn't fire up, or even possibly try it out with a different board..
I have looked through the ID pages with no luck, not sure if this was unique to this cabinet or not, and the game manual was really no help...
The only numbers I have found that may be of some help is on the main chassis board NEC PWK-065.
It's a bit hard to get decent pictures at the moment, the monitor is mounted vertically on a moving mount, but I can pull it if no-one can help with the pictures available.
Thanks in advance!
« Last Edit: May 25, 2007, 11:06:48 am by Angry_Radish »
SirPeale
  • Green Mountain Man
Re: Chassis ID help please
« Reply #1 on: May 25, 2007, 10:46:53 am »
That looks very much like a monitor I have *two* of.  Never could find out who made it.  Tube was made by Chung Hwa.  I think they make chassis too.
Angry_Radish
« Reply #2 on: May 25, 2007, 10:57:15 am »
The only hit I got on google went to the klov forums, and that wasn't very clear either..
http://forums.webmagic.com/ubbthreads/showflat.php?Cat=0&Number=192155&page=0&fpart=all&vc=1
Here's the tube I have:
« Last Edit: May 25, 2007, 10:59:39 am by Angry_Radish »
Ken Layton
  • Guru
  • Technician
« Reply #3 on: May 25, 2007, 12:25:59 pm »
Definitely a Japanese made monitor since it's a 100 volt unit and carries a Sega part number. Likely it's a Toei monitor since that was Sega's alternate monitor supplier when Nanao's weren't available during a production run.
Angry_Radish
« Reply #4 on: May 25, 2007, 01:47:28 pm »
Well for now I guess, I'll keep my fingers crossed that the monitor works once I get the board installed.
I'm a big fan of having the manual for anything I could work on (have to get the shop manual for any car I own  :) ), but I guess if the monitor is bad I can try the usual stuff, or swap it out..
Speaking of that, can you tell from the monitor pic what size tube this is? I've seen differing info from diff sites, one saying it's a 14, another saying 15...
Cheers!  :cheers:
Ken Layton
  • Guru
  • Technician
« Reply #5 on: May 25, 2007, 07:08:09 pm »
The number to the right of MATSUSHITA is the tube number. The number tells me the size, but I can't read it in your photos.
