Author Topic: Fixing mistakes and sander question  (Read 3545 times)
shredso
  • Last login:January 27, 2020, 09:23:27 pm
« on: May 23, 2007, 08:08:35 pm »
I'm buying a sander this weekend.  Any tips on what I should get?  I'm using the BYOAC book for the plans and I'm using 3/4" MDF (wish i got something lighter).  My angles on the control panel are a little off, so i figured i would sand them.  I'm hoping I can get away with a $50-60 finish or orbital sander.  Will I be sanding for hours without a belt sander?  I heard MDF sands pretty easily.  Thanks.
Re: Fixing mistakes and sander question
« Reply #1 on: May 23, 2007, 10:25:44 pm »
Belt sander sands super fast
Orbital sander is much slower
I have both
« Reply #2 on: May 23, 2007, 11:35:16 pm »
MDF practically melts under pressure from a sander.  Make sure you are in a well ventilated area or wear a mask - the dust is brutal.
ScottS
  • Last login:November 01, 2007, 02:21:30 pm
« Reply #3 on: May 24, 2007, 12:08:09 am »
Get a random orbit sander, the bigger the better. You can speed up material removal by using coarser grit sandpapers. With a random orbit sander, you're probably limited to 40 or 60 grit. Still that should be plenty fast enough.
I have a 3x21" belt sander and I wouldn't recommend it for this task; too difficult to control.
NiteWalker
  • Last login:April 25, 2022, 07:33:24 pm
  • Routers can do anything.
    • SimpleCase Custom Arcade Stick Enclosures
« Reply #4 on: May 24, 2007, 11:33:49 am »
I'd go with a random orbit and 60 grit.
One of the best sanders out there.
It's 9am. I'm calling it a nite.
« Reply #5 on: May 24, 2007, 11:35:47 am »
Tempting.  My sander sucks, took hours to strip a simple flat cabinet door.
NiteWalker
« Reply #6 on: May 24, 2007, 11:40:21 am »
For that chad, you're probably better off with a belt sander. Porter Cable just released a mini belt sander I'm in love with because I don't have the need for a full size belt sander.
« Reply #7 on: May 24, 2007, 11:42:07 am »
Cool, I'm going to watch that.  I'm in the same boat, don't need a full size belt sander but could use a really good small one.
NiteWalker
« Reply #8 on: May 24, 2007, 11:44:17 am »
There will probably be a father's day sale soon, so watch for that. Some items are already advertised with a 25% off discount like some bosch jigsaw blades and a few workmates. A while ago the sander went on sale for $99 shipped. That's a good price for it.
« Reply #9 on: May 24, 2007, 12:03:13 pm »
I'd be sold if there was an easy way to mount it perpendicular to a worktable for accurate edge sanding.
