Author Topic: Cabinet Cutting Question...  (Read 1927 times)
shawnzilla
  • Last login:May 05, 2022, 12:01:55 pm
« on: April 17, 2003, 04:16:09 pm »
When cutting the two sides of my cabinet, is it generally better to:
a) Clamp two sheets of MDF together and cut both sides at the same time?
b) Cut the two sheets seperately?
thedemo
  • Last login:May 21, 2003, 06:30:04 pm
  • I want to rule the world
Re:Cabinet Cutting Question...
« Reply #1 on: April 17, 2003, 04:34:36 pm »
Clamping the 2 sides together and then cutting would make the 2 sides basically identical. Then you would use a circular saw with a straight edge to make the cuts. The only problem with this would be at inside corners. Since the circular saw doesn't cut straight up and down it kinda cuts on a back 45 degree angle. You would have to flip the sheets over to finish the cut with the circular saw. Or you probably could use a jigsaw, but you would need to find really long blades. Most jigsaws don't have a stroke long enough with a standard blade to cut through an 1 1/2inches of MDF. Otherwise any other straight on across the sheet cut will be great with the circular saw.
Brentley_11
  • Last login:December 19, 2004, 09:29:40 pm
    • GMR -=- Game Maker Resources
« Reply #2 on: April 17, 2003, 04:35:45 pm »
I would go with "a" but I'd say that It would depend on your accuracy and the tools you have to work with.  At home I have a dinky table saw and I wouldn't trust raising the blade to cut 2 sheets at once but at school, I have access to a very big and good table saw and I would definitely cut 2 at once time.
Homebrew
  • Last login:May 03, 2012, 09:48:55 pm
« Reply #3 on: April 17, 2003, 04:57:06 pm »
Ideally i think it would be best to cut both sheets at once for accuracy's sake.  But as mention, its a bit more difficult to do this.  I tried this at first, but decided against it when i got to the first non straight cut.  My jigsaw couldn't handle cutting the curve through 2 sheets.  Something to keep in mind if you cut the sheets individually is that as long as you are recessing the other panels 1/2" to 3/4" like you typically see, its gonna be hard to notice slight differences in the 2 sides.  Its only when you have pieces that are flush can you notice differences.  Does that make any sense?  If not i'll try to clarify.
-Kevin
BobA
  • What Me Worry?
« Reply #4 on: April 17, 2003, 06:41:51 pm »
If you have the equipment to do it then you could cut both sheets together for accuracy.   2 sheets of MDF are very heavy and you would probably need help making the initial cuts because of the weight of the sheets.
BobA
slug54
  • Last login:June 12, 2014, 09:00:21 pm
  • Man, I hope this cab fits through the door way!
    • Arcade Extreme
« Reply #5 on: April 17, 2003, 07:09:37 pm »
I clamped mine together and cut them with a circular saw.
If i remember right, I made all the cuts except for the part
that parallels the monitor near where the glass mounts to the sides and above the C-panel.
I then un-clamped the sheets and did a plunge cut with the circ saw to make this cut on each sheet. I cut the remaining 2 "or 3 " between the cuts with my jig saw.
My cab is based on a defender machine and that was the only cut that was tough to make.
                          Slug54
pocketz
  • Last login:June 28, 2004, 10:42:03 pm
  • INSERT COINS
    • arcade addiction
« Reply #6 on: April 17, 2003, 08:01:12 pm »
i clamp them together and use a circular saw for the long straight cuts. i use a jigsaw for the curves and corners. i didnt have a problem with the jigsaw, go real slow so the blade doesnt twist. then i used a power sander to even up all the edges.
-pocketz
shmokes
  • Don't tread on me.
    • Jake Moses
« Reply #7 on: April 17, 2003, 08:18:27 pm »
I was planning to cut them separately, choose one for my guide and route the other down to make them exact.  Is there any reason not to do it this way?
Best Kid iPad Apps
thedemo
« Reply #8 on: April 18, 2003, 11:09:55 am »
that idea will work, using a flush cutting bit...
probably gonna kill the router bit especially if you go to fast
