Author Topic: A twofold problem  (Read 1543 times)
Justin Z
  • Last login:December 18, 2025, 09:47:41 am
A twofold problem
« on: May 21, 2007, 10:11:15 pm »
(my apologies in advance for the obscurity of the description to come, but these are problems described about a monitor I would have to purchase sight unseen)
I am considering purchasing an Operation Wolf game but the owner says that "sometimes the screen goes squiggly, other times it's fine but [shifted] to the left."  I am hoping this is a common or at least easily recognizable problem so I can gauge how much work it will take to repair.
Any suggestions are appreciated -- thanks in advance.
~Justin
northerngames
  • Trade Count: (+18)
Re: A twofold problem
« Reply #1 on: May 23, 2007, 11:18:09 am »
more then likely something is loose or cracked if it switch's screen's have him turn it on and give the machine a wiggle and see if it matters.
modessitt
  • Last login:October 17, 2021, 07:02:28 pm
  • Technician
« Reply #2 on: May 24, 2007, 01:54:11 am »
First of all, it helps to know what type of monitor it is, as certain monitors have certain common failures that cause these types of problems.
It sounds like a hold problem.  If the caps are starting to dry out and fall out of tolerance, the picture will sometimes roll (go squiggly) randomly, or lock into position off center.  A cap kit will usually fix this, but you can't really write it in stone until you've had a chance to see it in person and do your own investigating....
Working Games:Joust CT,Gyruss UR,Pong,Battlezone UR#1
Current Proj's:Battlezone UR#2
Cheap/Free Cabs Wanted: DK,KarateChamp,Shinobi,Ghosts&Goblins,CircusCharlie,10ydFight,PolePositnCP,RallyX,Frogger
Justin Z
« Reply #3 on: May 24, 2007, 12:09:33 pm »
Okay thanks for the suggestions.  That is kind of what I thought, but wanted to see if anyone agreed.  I'll let you know if I learn anything else.
