Author Topic: IPAC VE  (Read 3421 times)
Karaokedude
  • Last login:October 16, 2007, 12:21:00 pm
IPAC VE
« on: May 21, 2007, 08:44:11 am »
has anyone tried the Ipac VE with Wincab
I have just recieved one the main reason for getting it was the small form factor PC i want to use only has USBs and no PS2 connections
i want to programme it for a numeric keypad
so I need to remap some keys to 0-9 the others arn't critical but the VE looses its programming on power down
JustMichael
  • Mmmmm!! Cheesecake!!
Re: IPAC VE
« Reply #1 on: May 21, 2007, 01:33:59 pm »
According to the documentation on the Ultimarc website:
Running from the command line.
You can run WinIPAC IPD from a command line giving an "invisible" way to download a specific keycode configuration to the I-PAC board. Just enter "WinIPAC nnn.IPC" where the correct IPC file is specified. This is how the Launcher program and MAMEWAH drives WinIPAC.
I would guess if you had a batch file that ran the programming utility then ran WinCab, you could do what you want.
Chris
  • Moderator
    • Chris's MAME Cabinet
Re: IPAC VE
« Reply #2 on: May 21, 2007, 03:13:40 pm »
You can remap WinCab to anything as well, so if you can't get the VE mapped the way you want look in controls.ini to remap WinCab to match the VE.
--Chris
--Chris
