Author Topic: Analog Arcade Monitors  (Read 1355 times)
NukeBlast
  • Newbie
  • Last login:June 13, 2007, 09:34:58 pm
« on: May 19, 2007, 02:27:27 pm »
Just to verify, am I correct to assume that analog arcade monitors do not save the screen geometry when you change resolution?  Will a digital monitor keep the geometry between resolutions?
Since switching between games in MAME often means various resolutions, I don't want to be stuck adjusting the screen for every new game I load.
Thanks for the help.
Joystick Jerk
  • Last login:June 26, 2024, 05:10:33 pm
  • Slave to the stick.
Re: Analog Arcade Monitors
« Reply #1 on: May 19, 2007, 07:17:49 pm »
You are correct sir. Analog monitors store their current settings only, whereas a digital will store the settings for all modes and resolutions and bit depths.
ahofle
    • Arcade Ambience Project
« Reply #2 on: May 20, 2007, 01:13:12 am »
Well that's partially correct.  It's only an issue though (in my experience anyway) with a multisync monitor when you go from a 15khz mode to a 25 or 31khz mode.  If you just have a standard CGA monitor (15khz only), you really only need to adjust the settings once for pretty much everything.  When I had my plain analog CGA monitor, I did not have to adjust the geometry at all when switching games once I got a good balanced setup for all games.
