Author Topic: Hantarex Polo 25" Monitor Problem  (Read 1885 times)
whiful
  • Last login:May 19, 2007, 06:41:52 pm
« on: May 17, 2007, 05:19:47 pm »
Anyone got any idea whats wrong with this monitor? I've tried all adjustments from the remote control already, and no luck. Thanks for any help in advance!  :)
grantspain
Re: Hantarex Polo 25" Monitor Problem
« Reply #1 on: May 17, 2007, 05:22:45 pm »
polo 1 or 2?what frequency is the game board 15k or 25k
if the game board is standard 15k then check the following
if its polo 1 then you vertical hold is wrongly set,check it again
if its polo 2 then maybe its set to 25khz instead of 15khz on the jumper plugs
« Last Edit: May 17, 2007, 05:24:39 pm by grantspain »
whiful
« Reply #2 on: May 18, 2007, 11:15:58 am »
Still no luck  :( Any other ideas? Its a polo 1 monitor, and standard 15k game board.
grantspain
« Reply #3 on: May 18, 2007, 01:10:36 pm »
whats the history with this,did the game just go like this or have you swapped a board or anything else?
whiful
« Reply #4 on: May 19, 2007, 06:34:56 pm »
It was working fine, and then all of a sudden just went like that. It was repaired about 2-3 weeks ago, supposedly two caps on the horizontal output were changed. Thats all I know.
grantspain
« Reply #5 on: May 20, 2007, 03:30:39 am »
there are a couple of caps, transistors and an ic that can cause this sort of problem but its very rare,look at t110,t112,c149,c150 and ic 104 and the only other possibility could be a faulty vert hold pot
