Author Topic: control panel  (Read 1314 times)
SolidMetal
  • Last login:April 19, 2003, 01:19:43 pm
control panel
« on: April 17, 2003, 05:18:06 am »
can someone give me any tips on how to build a four player panel, this is what i want on it (might seem like alot, i'm not sure)
ok i need 1, four joysticks
               2, four buttons for the players on the far left and far right ( button for coin, start and like in gauntlet fire and magic)
               3, the front two i want six buttons each for other games like fighting and so on
               4,a trackball in the centre somewhere for mouse nav and games and also a spinner
phew thats not asking too much is it lol
what do i need to use to make this panel?
thankyou SolidMetal
(P.S.) plans would be even better
« Last Edit: April 17, 2003, 05:19:59 am by SolidMetal »
paigeoliver
  • Awesome face!
Re:control panel
« Reply #1 on: April 17, 2003, 05:37:05 am »
With a 4 player panel I would put the coin buttons down lower on the cabinet by the coin door (to keep the panel clean). And then add all the start buttons at the very top in the middle. You could actually do away with them altogether if you wired up either a 4-player coin mech, or a shift button (shift the start buttons to insert coins for the respective players).
Most spinner games play allright with a trackball. I never saw the need to add a spinner to a panel that already has a trackball on it.
The panel I use is only a small one player panel. It is a Cherry Master cabinet and the control panel is about the size of a Pac-Man panel. I had someone make me an all metal panel.
I have (from left to right), 8-way leaf switch stick,  4-way stick (Ms Pac/Galaga replacement stick), 6 buttons (Street Fighter layout), PS2 Arcade trackball, then Player one and 2 start buttons, and an escape button. The start buttons are Mouse 1 and Mouse 2 respectively. The escape button is hooked up to the Ipac and puts in credits in MAME, but it is wired up as Escape, because so many other applications and emulators have escape hardwired as a needed function to exit or get to the menu.
