Author Topic: Need Help!!! MAMEWAH COnfig issue!!!  (Read 1481 times)
RockCandy24
  • Last login:June 28, 2007, 10:42:13 am
« on: May 15, 2007, 04:05:22 pm »
Hello all! I am new to this hobby and am having some problems. I have configured MAMEWAH V162 to run with MAME (V113 & V061) and it works like a champ. All the information I needed was available on this site and net.... It took me a while to work through configuring it but I finally got it up looking the way I want it to. Now I am trying to configure some various console emulators and coming up with nothing. I have been at this for days, I know it is a newbee mistake I am sure. I have tried using various example *.ini files I have found here and on other sites (CPViewer) with no luck. My first attempt is the modified FCEU I got off of the CPViewer site. The closest I have come to getting anything to work is when I copy my MAME *.ini file and re configure it for FCEU.... It looks like this:
### NES.ini (mamewah v1.62) ###
emulator_title                            Nintendo
### List Generation Settings ###
rom_path                                  c:\arcade\nes\roms
rom_extension                             zip
dat_file
nms_file
catver_ini_file
list_generation_method                    rom_folder_vs_listxml
### Execution Settings ###
pre_emulator_app_commandlines
emulator_commandline                      c:\arcade\nes\fceu.exe [name]{nodosbox}
post_emulator_app_commandlines
general_app_commandlines
### Artwork Settings ###
artwork_image_paths                       c:\arcade\nes\snapsth]\art9;[emuexepath]\art10
movie_preview_path                        c:\arcade\nes\previews
movie_artwork_no                          1
enable_fuzzy_search                       0
history_dat_file
history_dat_artwork_no                    2
### Screen-Saver Settings ###
enable_music_in_screensaver               1
select_random_game                        0
saver_type                                gamelist_slideshow
movie_path
movie_fullscreen                          1
quit_delay                                0
saver_commandline
### Additional Settings ###
music_path
lcd_display_file_path
description_display                       [description]{scroll}
### Settings used by MAMEWAH ###
current_list                              0
What happens is when I try to generate a game list FCEU opens in a small window, no roms load to my layout list and i get an "Error opening "-listxml"! message. (I am putting a screen shot of the error on here.) Now I am not a complete tard.... I obviously know this has something to do with the "list generation method" setting in my *.ini file but when I remove that and set it to auto or rom folder nothing happens at all. Once again I am sure I am just working my way through common mistakes..... but pulling my hair out every night is becoming frustrating. Thanks in advance for any help anyone can offer!
si vis pacem, para bellum
If you wish for peace, prepare for war.
Jedirampage
  • Last login:July 08, 2008, 06:54:08 pm
Re: Need Help!!! MAMEWAH COnfig issue!!!
« Reply #1 on: May 15, 2007, 06:41:10 pm »
Heyd dude,
Try this
c:\arcade\nes\fceu.exe "[rompath]\[name].[romext]"{dosbox}{safelaunch}
hope it helps
Jedirampage
« Reply #2 on: May 15, 2007, 06:42:13 pm »
oh and on list generation method, just have Rom_Folder
patrickmaher
  • Last login:May 30, 2009, 06:45:05 am
    • Patrick Maher
« Reply #3 on: May 15, 2007, 06:48:14 pm »
The reason you get the error is that -listxml is not valid to use for NES. You should be using rom_folder but it gives you no response because MameWah does not see any roms and you get a blank list. MameWah does not see this as an error so it does not give you any visual response.
List generation should be
Check that your roms are really at the path you have specified
Also check that the roms are .zip files, if not you need to change zip to the correct extension on this line
rom_extension                             zip
You can also look at the mamewah.log to see what it says is happening during the list generation.
RockCandy24
« Reply #4 on: May 15, 2007, 07:20:22 pm »
OK I changed the files as suggested (Thx Jedi) and I verified that the directory to the roms folder is correct and that the roms in that folder are all zip files. This time when I generate list the message window pops up and says scanning rom folder (or something like that) and then closes with no change. Here is the log that is generated:
5/15/2007 7:12:17 PM MAMEWAH v1.62 launched
5/15/2007 7:12:17 PM Cursor scheme: Windows Default, Arrow: C:\WINDOWS\Cursors\arrow_l.cur, Wait: (None), AppStarting: (None)
5/15/2007 7:12:17 PM Desktop colour: 0
5/15/2007 7:12:17 PM Wallpaper filename: C:\Documents and Settings\Michelle\Local Settings\Application Data\Microsoft\Wallpaper1.bmp
5/15/2007 7:12:17 PM Desktop display mode: 1024x768 @ 60Hz, 32bit colour
5/15/2007 7:12:17 PM Decimal symbol: '.'
5/15/2007 7:12:17 PM Games list read: Old Mame-0.lst
5/15/2007 7:12:17 PM Layout selected: C:\Arcade\MAMEWAH V162\config\Old Mame\\layout.lay
5/15/2007 7:12:18 PM No. joystick devices attached: 0
5/15/2007 7:12:18 PM Ctrlr file selected: C:\Arcade\MAMEWAH V162\config\mamewah.cfg
5/15/2007 7:12:18 PM Keyboard enabled
5/15/2007 7:12:21 PM Layout selected: C:\Arcade\MAMEWAH V162\config\NES\\layout.lay
5/15/2007 7:12:21 PM Games list read: NES-0.lst
5/15/2007 7:12:24 PM List generation started...
5/15/2007 7:12:24 PM List generation aborted
5/15/2007 7:12:24 PM Games list read: NES-0.lst
5/15/2007 7:12:49 PM MAMEWAH quit
So now I think It got better...... I think  :banghead: Any more insight?
gonzo90017
« Reply #5 on: May 15, 2007, 09:00:05 pm »
I was having the same problem a few days ago. The problem is with the mamewah version you're using. Use this one http://files-upload.com/230787/mamewah_v162b13a.zip.html and you should be ok.
