Author Topic: MLCS slot cutter assembly  (Read 2489 times)
karlpenney
  • Last login:June 04, 2020, 08:36:58 pm
« on: May 14, 2007, 03:21:08 pm »
Does anyone know the proper order of assembly of the arbor, cutter, washers, bearing, spacer, etc. for the MLCS 1/16" 3-wing slot cutters?  I have been trying to find out from MLCS, but they don't sound too sure about it.  They suggested the order is arbor, cutter, washer, bearing, washer, spacer, nut.  However, the arbor shaft is a little bit narrower near the top, so if you put the cutter on first, it can move sideways a bit.  Not sure if this is critical or not, but just want to make sure before I start.
NiteWalker
  • Last login:April 25, 2022, 07:33:24 pm
  • Routers can do anything.
    • SimpleCase Custom Arcade Stick Enclosures
Re: MLCS slot cutter assembly
« Reply #1 on: May 14, 2007, 04:25:53 pm »
2 washers, cutter, washer, BEARING ;), nut. Mine is a whiteside but it's probably universal for most brands.
« Last Edit: May 14, 2007, 08:08:30 pm by NiteWalker »
It's 9am. I'm calling it a nite.
karlpenney
« Reply #2 on: May 14, 2007, 07:18:52 pm »
2 washers, cutter, washer, BEARING, nut - right?
the arbor from MLCS came with 2 washers and a spacer, which is about 1/4" thick.  mlcs did come back and say to install this spacer first, cuz otherwise the cutter can move laterally because of the narrower shaft at the top.  however, with everything on, there are not enough threads left at the end to fully engage the nut, it only goes about halfway.  probably won't fly off, but you never know.  i guess i'll have to get a couple more washers to replace the spacer instead.  it should've come with the correct parts needed in the first place though.
NiteWalker
« Reply #3 on: May 14, 2007, 08:12:25 pm »
Yeah. Sorta forgot about the bearing... :-[
But yeah you have it figured out. I wouldn't even use the second washer.
That's why I stick with whiteside. ;)
