Author Topic: Fun with Lexan!!!!  (Read 5273 times)
Jedirampage
  • Last login:July 08, 2008, 06:54:08 pm
Fun with Lexan!!!!
« on: May 10, 2007, 11:54:44 pm »
Hi all,
I just got a huge sheet of lexan to cover my control panel and i need advice on how to cut the  button holes, what kind of bit should i use and how hard is this stuff to cut?  i'd imagine i can't use the standard spade bit that i used to drill the original button holes
Also i have a standard 3" Happ trackball with a mounting kit and am clueless as to how i'm going to workaround the lexan with this.  I planned on mounting the trackball the standard way with the mounting kit and everything however do i mount this on top of the lexan, or can i mount the kit to the board and cut a circular hole in the lexan that just exposes the actual trackball??
Please help
  • Last login:Today at 04:50:19 pm
Re: Fun with Lexan!!!!
« Reply #1 on: May 11, 2007, 12:47:55 am »
Hi all,
Please help
I cut my first piece of plexi with a standard spade bit spinning in reverese and going REAL slow. You pretty much melt your way through. What I eventually did was purchase a 5/8" forstner bit and cut a hole just big enough for a flush trim bit on my router to go through and trim up the hole that way. Much much easier.
Here is my showcase cabinet:
http://forum.arcadecontrols.com/index.php?topic=55021.0
near the bottom of the first page and at the top of the second I discuss what I'm doing about my plexi. It may give you some ideas - if not - read some other peoples projects. Theres some talented folks in these forums.
« Last Edit: May 11, 2007, 12:51:01 am by leapinlew »
NiteWalker
  • Last login:April 25, 2022, 07:33:24 pm
  • Routers can do anything.
    • SimpleCase Custom Arcade Stick Enclosures
« Reply #2 on: May 11, 2007, 01:47:50 am »
Lexan will not crack. I cut it on the tablesaw to rough size, flush trim it to the control panel with a router and flush trim bit, drill with a spade or forstner bit and it won't crack. Lexan is a polycarbonate and is shatterproof. Very easy to work with, but less scratch resistant than acrylic.
It's 9am. I'm calling it a nite.
Jedirampage
« Reply #3 on: May 11, 2007, 04:23:59 pm »
What would i use to cut the hole for the trackball?
shardian
« Reply #4 on: May 11, 2007, 04:46:03 pm »
Look for one of these at Lowes, or your favorite tool store.
« Reply #5 on: May 11, 2007, 04:48:43 pm »
What is that called?
NiteWalker
« Reply #6 on: May 11, 2007, 04:50:25 pm »
A flywheel cutter or a circle cutter. ;)
« Reply #7 on: May 11, 2007, 04:51:15 pm »
Attached to a drill?  Seems like it would be hard to do without a drill press.
NiteWalker
« Reply #8 on: May 11, 2007, 04:53:21 pm »
You can only safely use those in a drill press. Using a hand drill would probably result in workpiece and/or finger destruction/mangling.
« Reply #9 on: May 11, 2007, 04:56:47 pm »
Woo I'm learning.   ;D
NiteWalker
« Reply #10 on: May 11, 2007, 05:02:07 pm »
A better choice. It attaches to the plunge base of your router. Works great. It's how I cut the center hole in my router table.
« Reply #11 on: May 11, 2007, 07:34:50 pm »
Nice.  I may end up with one of those once I start building CPs.
NiteWalker
« Reply #12 on: May 11, 2007, 07:39:14 pm »
It really is great. Very accurate and not as flimsy as some state. They also sell a more versatile model that's worth the extra $11 as it lets you make circles up to 18 3/16". Very useful. Watch for a slae though; when I bought the model 400 I got it for just under $14 and the model 200 I got for $22.
scotthh
  • Last login:June 06, 2012, 10:03:42 pm
« Reply #13 on: May 11, 2007, 09:19:36 pm »
I am planning on removing the trackball from the mounting kit and using the same method leapinlew used for his buttons
Is there any reason not to use the flush trim bit with the trackball plate as a guide?
scotthh
« Reply #14 on: May 13, 2007, 06:51:40 pm »
The metal mounting plate is a thin .12". There is no way to remove all of the Lexan and have the bearing run solidly on the metal. See the attached picture, the metal gets wedged in the gap between the cutter and the bearing (maybe the gap is big because I wasn't using an expensive bit?) I wound up putting thin pieces of wood between the Lexan and the CP and clamping that down. If I were to do it again. I'd probably make a template from a piece of MDF to cut the trackball hole. Then I'd have the hole in the Lexan a bit smaller so it was
Senator
  • Last login:June 10, 2008, 10:25:46 am
« Reply #15 on: May 18, 2007, 03:35:08 pm »
I was able to mount the spacer (just the spacer) in the trackball mount and use that as a guide for the flush trim bit.  See the piece in the top of the photo from the Happs site.  Actually, I think I needed a washer or two to keep it at the proper depth.  Worked like a charm.
