Author Topic: $3.95 for a PC track ball!  (Read 2972 times)
creatine28
  • Last login:July 26, 2012, 03:41:48 pm
  • Which way to the Arcade?
« on: April 16, 2003, 01:16:00 pm »
Thought someone might be interested in these.  I was just at th store yesterday, and they looked pretty good for only 3.95!
http://www.softwareandstuff.com/h_acc_mactrack.html
marcoval
  • Last login:December 02, 2004, 02:40:59 pm
  • www.scottishninjas.com
Re:$3.95 for a PC track ball!
« Reply #1 on: April 16, 2003, 09:34:10 pm »
Sweet, these seem like the ones that are currently OOS at outpost.com.
Every millennium
A warrior emerges.
Trained in the deadly arts of the ninja.
Moving with the swiftness of the wind
Striking with deadly accuracy
They are proud
They are strong
They're Scottish
Chris
    • Chris's MAME Cabinet
« Reply #2 on: April 16, 2003, 10:33:08 pm »
I have one of these, they're not great... I'll probably use the board of mine for a mouse hack to an arcade trackball...
--Chris
--Chris
shmokes
  • Don't tread on me.
    • Jake Moses
« Reply #3 on: April 17, 2003, 01:33:25 am »
Has anyone mounted one of these inconspicuously on a control panel with only the ball showing through the top of the panel?  I'd like to do this for my steering wheel panel -- not for trackball games, but for mouse support, since my 270 degree steering wheel will probably be used more for Windows games than Mame games.  I need to be able to navigate menus in bad programs that can't be navigated with the wheel.
I've already got a few of them...ordered from Outpost when they were available.  I've got the part, just not the skills.  Any help?
Best Kid iPad Apps
Chris
« Reply #4 on: April 17, 2003, 11:15:17 am »
The problem is that the way these are designed, there is a ton of friction.  If you remove the upper part of the shell and lube the moving parts a bit, it works much better, but you'll have a lot of backspin.  I had to break out every other tooth on the optical encoder wheel, which helps reduce the backspin at the expense of sensitivity... but I still ended up not installing it in my panel.
I'll probably buy the $25 arcade trackball from Wico and hack it to the board of this trackball.
--Chris
--Chris
NAH
  • Last login:November 17, 2016, 06:32:02 pm
    • Mame Journal
« Reply #5 on: April 24, 2003, 04:22:07 pm »
Chris or Shmokes:
How big is the diameter of this trackball?
Chris
« Reply #6 on: April 24, 2003, 04:34:32 pm »
About 2".
--Chris
shmokes
    • Jake Moses
« Reply #7 on: April 25, 2003, 08:01:32 pm »
Yes...1.999 inches is the largest reading I could find with my calipers.
I'm not worried about backspin as I want to mount this purely for cursor navigation on a panel with a steering wheel.  I plan to play a lot of Windows games with the wheel in addition to Mame and many games have menus that cannot be navigated with the wheel.
Best Kid iPad Apps
Chris
« Reply #8 on: April 25, 2003, 10:55:55 pm »
In that case, it should be fine if you remove the upper cover...
--Chris
--Chris
SNAAAKE
  • -Banned-
« Reply #9 on: April 25, 2003, 11:19:58 pm »
I have a question.  :)
These work as a mouse right?
I get to control windows with this trackball right(USB)?
How would it be to mount the trackball?any link for a similer trackball installation??
I really dont care about trackball games but it would be nice if I install this and use for navigation.
Anyone ;D?
nullb0y
  • Slow In Fast Out
    • WAT Racing
« Reply #10 on: April 26, 2003, 12:13:25 am »
is this an actual store or do i have to e-buy it i like the way it looks and it might work good if hacked around a bit ... just curious i broke my old trackball thewheels went flying
Slow In Fast Out
shmokes
    • Jake Moses
« Reply #11 on: April 26, 2003, 11:03:11 am »
I took one apart last night and I think it will be really easy to mount.  Not sure about the buttons.  There are tiny little microswitches soldered to the circuit board.  I'd like to desolder them and wire regular happ pushbottons in their place, but that's kind of beyond my skill.
At any rate, If you just router the correct depth recess from the bottom of your panel and drill a hole about 2 1/8, maybe 2 1/16" through the panel I think you'd be set for just windows navigation.
Best Kid iPad Apps
