Author Topic: 39" ARCADE MONITOR PROBLEMS  (Read 2542 times)
nheuer
  • Last login:September 16, 2009, 02:14:04 pm
« on: May 05, 2007, 03:40:46 pm »
Hello All
I have a Wells Garner 39" Dual Scan Monitor (15khz & 25khz) I have it hooked up to a jpac and arcadevga. The problem I am having is that when ever I open a window the screen becomes distorted.
Link to Picture
http://www.nickandjenni.com/monitor1.htm
Once I load a game it is fine?????
http://www.nickandjenni.com/monitor2.htm
but I can not see anything to set the settings. anyone know what is going on?
Nick
grantspain
Re: 39" ARCADE MONITOR PROBLEMS
« Reply #1 on: May 05, 2007, 06:16:15 pm »
you should contact ultimarc directly
SirPeale
  • Green Mountain Man
« Reply #2 on: May 05, 2007, 07:34:16 pm »
Some kind of funky sync issue probably related to the resolution.
nheuer
« Reply #3 on: May 05, 2007, 08:22:17 pm »
Hello
I have treid various resolutions and it is currently set at 640x480 32bit??????
Nick
SirPeale
« Reply #4 on: May 05, 2007, 09:19:06 pm »
What I mean is the game sends a signal that your monitor likes, but Windows isn't.
nheuer
« Reply #5 on: May 05, 2007, 10:02:13 pm »
I have also tried to cofigure windows and the picture is fine when thier is no movement on the screen but once I open another window it becomes distorted. I am beating my head against a wall. what settings do you all use when running an arcade monitor?
Nick
Rickn
  • Last login:May 08, 2020, 01:32:28 pm
« Reply #6 on: May 06, 2007, 10:06:20 am »
Just for the heck of it, reduce the brightness and contrast to see if anything change- I doubt it but it could be an ABL problem?
We should be building our 39" Tri-res by the end of the week. If I remember I test it to see if this happens?
Rick Nieman
Rick@Niemandisplays.com
www.niemandisplays.com
Always happy to help.., for the best in displays
Rick Nieman
1023 Rife Rd Cambridge, Ontario Canada N1R5S3
519-621-1722
nheuer
« Reply #7 on: May 06, 2007, 10:35:51 am »
Hello
That is what andy said and it did not change anything. Could it be the H-hold???
grantspain
« Reply #8 on: May 06, 2007, 05:39:26 pm »
maybe you could tweek the hold
psychohack
  • Last login:May 01, 2011, 05:33:38 am
« Reply #9 on: May 06, 2007, 09:31:31 pm »
Maybe you should have someone qualified to work on electronics look at it before you shock the  :censored: out of yourself! Or, you can bring some of those parts to work with you tommorow so I can try it on my monitor. I might break down and order some parts tonight or tommorow. I am tired of waiting for you to get yours working and I just made $1000 on ebay selling those old machine parts :)
 >:D
 >:D
 >:D
 >:D
