Author Topic: Actual construction of the cp question  (Read 1193 times)
rhoelsch
  • Last login:August 18, 2018, 08:13:16 pm
  • That...that thing's operational!
« on: April 15, 2003, 11:08:08 pm »
Ok, this is bad, I know... I, er, can't build a box... do I need to mitre my cp sides?  I found L brackets at depot, and was going to use 1/4" wood screws to fasten the sides together via those brackets...going to leave the bottom open to get at the innards...should I screw the top down into the sides?  Will L brackets be ok for the sides?  How are people doing this?  Hard to know which examples will show this, and not sure how to word it for a search...
Thanx!
Now witness the power of this FULLY OPERATIONAL Mame machine!
Sasquatch!
  • Toot-Toot!
    • Arcade Paradise
Re:Actual construction of the cp question
« Reply #1 on: April 15, 2003, 11:39:30 pm »
L-brackets would work, but using 1"x1" wood strips would certainly be less expensive.
Rather than screwing the top down to the sides, most people (and companies) use panel clamps.
