Author Topic: Hantarex MTC-9000 cooling/rebuild...  (Read 2467 times)
ifkz
  • Last login:March 14, 2020, 09:55:44 pm
« on: April 27, 2007, 11:37:04 am »
Hi guys,
My Hantarex MTC-9000 monitor died a week ago, and my Centipede has been down since then   :'(
I don't know what failed so I ordered all the replacement parts I could find.  I'm slowly installing a cap kit, HOT, and flyback on it thanks to the legendary Bob Roberts.  I hope this fixes it, this is my first monitor rebuild!
Questions:
1.  Where is the HOT?  I can't find a manual anywhere.
2.  I read a thread from 2006 about a fan with this model because of heat.  Should I think about installing one?  Mine didn't have one and ran fine without it...for about a month.  The monitor is used and the chassis has had some repair work, so I don't know if it was age or what got it.
3.  Is this a good monitor....I read a webpage that mentioned it was "the cr@ppiest arcade monitor ever made."  I guess this last one doesn't really matter, but...
Nothing is like stepping back, looking at your games, and thinking 'wow, I've done this, and I have these!'
grantspain
Re: Hantarex MTC-9000 cooling/rebuild...
« Reply #1 on: April 27, 2007, 12:47:10 pm »
the horizontal deflection transistor(hot) should be a bu508 found sprung clipped to the flyback heat shield(underneath the big load resistor if memory serves me correct)
i don't believe the fan is needed with yours
its not the crappiest monitor,it just had a lot of silly problems.
http://www.freeinfosociety.com/electronics/schemview.php?id=2245
ifkz
« Reply #2 on: April 30, 2007, 10:33:24 am »
Thanks to everyone that read and especially replied to this post.  I replaced the HOT, flyback, & gave it a cap kit.  I plugged it in, and turned it on, and was greeted with puffs of white smoke from the neck yoke.  It really did die and my replacement parts & labor didn't fix it.  Since Hantarex glued the neck yoke on the neck I think it's not repairable.  What a mess, maybe I should try to sell my rebuilt chassis to recoup some of my losses.  I only got two months of play out of it before it burned out, and I paid $100 for it, used.  :'(
Too bad, the picture was excellent.  On the plus side my soldering skills have never been better, and I know a lot more about monitors now.  It's not really a silver lining though.
What does everyone do for replacement monitors?  Buy used and rehab them?  Buy a new Happs Vision Pro and not worry about it?  Buy cheap cabs and steal their monitors?   ???
SirPeale
  • Green Mountain Man
« Reply #3 on: April 30, 2007, 11:26:11 am »
Smoke from the yoke?  Did you plug it in wrong?
ifkz
« Reply #4 on: April 30, 2007, 11:32:21 am »
No, I triple checked everything, the caps, the connections, the flyback, the traces on the solder side of the chassis, everything.  So, so sad  :cry:
Ken Layton
  • Guru
  • Technician
« Reply #5 on: April 30, 2007, 12:40:02 pm »
I believe the horizontal output transistor needs to be insulated from the metal chassis on this model. Did you put a mica insulator and silicone heat sink grease on it?
grantspain
« Reply #6 on: April 30, 2007, 12:57:26 pm »
thats strange,i've never seen a yoke do that before unless you somehow reversed the yoke plug-sometimes you win,sometimes you lose :cry:
ifkz
« Reply #7 on: April 30, 2007, 02:35:11 pm »
Yes, the HOT is insulated and is on the same spot as the previous one.  The insulation looks similar to duct tape, but I'm sure it's a different material.
