Author Topic: My Second Jukebox Software: MultiJuke (1.11.4 Released: Touchscreen)  (Read 31324 times)
Space Fractal
  • Space Fractal
    • Space Fractal
Re: My Another jukebox software: MultiJuke (1.07 Released, "JPS")
« Reply #40 on: January 26, 2008, 03:03:10 pm »
here I need the multijuke.log file so I can see where it crashed.... I think you should create a account on the MultiJuke Forum (http://www.multijuke.com/forum) and add your log file. I can look on it what it happens.
[EDIT]
I have released v1.8.2 to fix even more bugs and log some more info, since it seen it a bug have been reappear under creating libraries on some some machines.
I need and hope I known where it crash using when invitate that file....
« Last Edit: January 26, 2008, 05:53:01 pm by Space Fractal »
Space Fractal
  • Space Fractal
    • Space Fractal
« Reply #41 on: January 29, 2008, 01:02:44 pm »
Finally, I got some crashes under creating libraries.
It seen it might been due with a faulty library files due to a previous crash (if you example have tried to create a library with non exists path or such).
Singles might even read wrong when unicode was used.
So I hope I have fixed most of these crash issues in V1.09 I release tomorrow danish time.
Version 1.09 is released: http://www.multijuke.com/forum/index.php?topic=94.msg326#new
I hope this one is more stable than the version 1.08 version around the library creation crashes.
as allways get it from download page: http://www.multijuke.com/index.php?item=download
« Last Edit: January 30, 2008, 10:54:43 am by Space Fractal »
Spaced Ace
  • Last login:November 03, 2010, 05:48:56 pm
  • "I'm surrounded by arcades!"
Re: My Another jukebox software: MultiJuke (1.09 Released: Info)
« Reply #42 on: January 31, 2008, 09:30:22 pm »
Does this software have an audio equalizer option?  If not, can you consider having that option in a future release please!?
Space Fractal
  • Space Fractal
    • Space Fractal
« Reply #43 on: February 01, 2008, 11:48:19 am »
nope, I have no planning to have such a feature in the application yet. There is other features that is by now more important.
Please:
Do not try to advertisement the same forum, in servial BOAYC forum's and then trying again trouch PM..... I dosen't like this type of forums you can see anything without registring anyway.
So I think I hold it here at the great BOYAC....
Space Fractal
  • Space Fractal
    • Space Fractal
My Second Jukebox Software: MultiJuke (1.10.3 Released: Visual)
« Reply #44 on: February 10, 2008, 05:03:40 pm »
There is a equalizer in bass.dll (windows), but I have not sure how it works in FMOD (Linux). Since I dosent want to have to many unique features for Windows, this is not the most important on this software. Mightbee or mightbee I add it, but is not high priotity (sorry also If I was a bit negative).
Otherwice I have released 1.10.X and have fixed a lots of bugs and cleaned up the visuals as well. Now look a much sharper, since I added the button infobar. This version should been more stable under creating libraries now.
Here is the screenshots of the new version:
http://www.multijuke.com/index.php?item=screenshots
News: http://www.multijuke.com/forum/index.php?topic=95.0
Download: http://www.multijuke.com/index.php?item=download
This version is released to Linux as well Windows.
Please Note: I have recently removed touchscreen support, since I think this skin work much better with buttons and have some issues. Instead I (might) create a third GUI target touchscreen.
« Last Edit: February 10, 2008, 05:06:43 pm by Space Fractal »
govee
  • Last login:February 19, 2012, 09:26:30 pm
Re: My Second Jukebox Software: MultiJuke (1.10.3 Released: Visual)
« Reply #45 on: February 10, 2008, 06:35:42 pm »
When do you plan to get the Touchscreen back in the program? I just got my ELO working with Ubnutu. Do you have an older version that has touchscreen that i could use till you get the new GUI wrote?
Space Fractal
  • Space Fractal
    • Space Fractal
« Reply #46 on: February 11, 2008, 06:27:05 am »
<EDITED>
yes, this is the highest priority plan to get a new touchscreen skin back again.
I messed the code up, and hence removed it completely. I simply want to get the first two skin optimized for buttons and have a third GUI using for touchscreen.
The new GUI Is now in currently in heavy development, even I have not have a touchscreen myself, but I design it with touchscreen in mind. The two other GUI was actually meant to been used with Arcade/numpad controllers and not touchscreen.
Even I call this new GUI as "Touchscreen GUI", you can still enable a mouse pointer, if you want it. In later stage, I  want the pointer to been controlled by joystick and button....
Until I wipe this new GUI up, you should been able to use this Linux Build:
http://www.multijuke.com/files/App/MultiJuke%201_06_3.tar.gz
Otherwise I PM you when I have some beta to test.
« Last Edit: February 11, 2008, 10:45:18 am by Space Fractal »
govee
« Reply #47 on: February 11, 2008, 07:09:54 pm »
thanks!
I guess I am missing something cause it does not respond to my touchscreen. All other programs do, so I am sure it is related to a setting in Multijuke that I cant find. So I guess I am asking if there is a setup requirement in your app for touchscreen use. By the way I never see my mouse as well.
Space Fractal
  • Space Fractal
    • Space Fractal
« Reply #48 on: February 12, 2008, 05:08:00 pm »
There a no mouse pointer in MultiJuke, until next release.
Did you see a touchscreen as movement controllers in config/controllers (even it sound a bit odd)? Otherwice I think you must wait a week. The new GUI is not far away (which is MUCH better than arcade GUI using with touchscreen).
If the setting is there (if I did not removed it), did the mouse respons (even you cant see the mouse pointer)?
Otherwice it might been why I removed it (mightbeen from around version 1.05 -> 1.06?), because I have messed some elements out, since some diddent work as it should. A least it should work in the onscreen keyboard... try to test it work here.
I got a PM, this was the last version with working touchscreen in Arcade GUI Mode:
 http://www.multijuke.com/files/App/MultiJuke%201_05_5.tar.gz
 http://www.multijuke.com/files/App/MultiJuke%201_05_5%20Setup.exe
« Last Edit: February 13, 2008, 02:09:54 am by Space Fractal »
Space Fractal
  • Space Fractal
    • Space Fractal
« Reply #49 on: February 16, 2008, 03:36:37 pm »
Yes, I still work on the new GUI and is begin to work with most basic things, but still many things to do left. So I guess it might take a another week or two, before MultiJuke got a full Touchscreen support.
Here is a little screeny how it would look and is of course have some configuration, like number of coverarts shown at once and other things.
Space Fractal
  • Space Fractal
    • Space Fractal
My Second Jukebox Software: MultiJuke (1.11b1 Released: Touchscreen)
« Reply #50 on: February 24, 2008, 06:43:27 pm »
I have finally release a Beta version of the new Touchscreen GUI, that do have some limits, hence I release this as a.
The major limit is, it only support one library and cannot switch to other library, like you can on other GUI. That screen is working on. There is few other issues as well.
Look what it happens at this thread, where there is download links and info:
http://www.multijuke.com/forum/index.php?topic=96.msg341#msg341
NB. Since the screenshot name use numbers as filename is because I used the half resoulutions version of the screenshot I toke by pressing F11 in MultiJuke (the full size use much more space and is in PNG).
EDIT:
Full 640x480 PNG Screenshots taken by the Screenshot feature (same as the 2 file attachments):
http://www.multijuke.com/multijuke/screenshots/8.png
http://www.multijuke.com/multijuke/screenshots/9.png
« Last Edit: February 25, 2008, 04:47:33 pm by Space Fractal »
Space Fractal
  • Space Fractal
    • Space Fractal
Re: My Second Jukebox Software: MultiJuke (1.11 Released: Touchscreen)
« Reply #51 on: March 03, 2008, 06:40:50 pm »
I have just released full v1.11 release for both Linux and Windows versions. All important Touchscreen features does now work and is now 100% usable.
This touchscreen GUI should run virtually any resolutions (4x3, 5x4, 16x9 and 19x10) and can been rotated vertical as well. The touchscreen GUI defaults is with mouse pointer enabled, but it can of course been disabled.
I do still want to keeps this simple, and I doesn't have plans to compete example Freebox on number of features and  skinable features. Instead this GUI was simply designed so there exists a touchscreen jukebox software, that exists both Linux and Windows. Later I see I can fixed touchscreen support on Arcade GUI as well (so both can been used and choice able). But this is not a high priority.
There might still have few quirks as well,but tell me on any of them (best on my dedicated MultiJuke forum, so I can keep this thread to announce releases.
Space Fractal
  • Space Fractal
    • Space Fractal
Re: My Second Jukebox Software: MultiJuke (1.11.4 Released: Touchscreen)
« Reply #52 on: March 22, 2008, 06:00:04 am »
Many bug fixes since 1.11.4 and also updated to sync with JSP version 1.05 (the added filename).
Change Log: http://www.multijuke.com/forum/index.php?topic=96.msg377#msg377
Linux version is also updated to 1.11.2, but the last two updates was only for some JSP fixes, hence no need to update Linuix version to 1.11.4, since there was no other change since 1.11.2.
Download:
