Author Topic: analogue controllers  (Read 3169 times)
grantspain
« on: April 26, 2007, 03:52:06 pm »
i need a bit of help,i have a rx-1 machine that utilizes a 4 button analogue flight control and i am having problems finding a replacement,although happ have this http://www.happcontrols.com/joysticks/95025100.htm
does anyone know of any other better priced alternatives
modessitt
  • Last login:October 17, 2021, 07:02:28 pm
  • Technician
Re: analogue controllers
« Reply #1 on: April 26, 2007, 05:15:46 pm »
What are you going to put it in?  You could save a lot of money if you could adapt a PC flightstick (if you can find an analog one).
Or buy a regular analog joystick and make it a flight stick using this method:
http://mamecheats.fateback.com/tutorial.htm
Or buy used.  Start watching E-bay or look for someone parting one out...
Working Games:Joust CT,Gyruss UR,Pong,Battlezone UR#1
Current Proj's:Battlezone UR#2
Cheap/Free Cabs Wanted: DK,KarateChamp,Shinobi,Ghosts&Goblins,CircusCharlie,10ydFight,PolePositnCP,RallyX,Frogger
grantspain
« Reply #2 on: April 26, 2007, 05:21:50 pm »
the problem i have is that its got to have 4 buttons on the grip itself,the company that make the machine are based in spain near barcelona but i have been waiting 2 weeks for a reply from them :angry:
modessitt
  • Technician
« Reply #3 on: April 26, 2007, 05:31:09 pm »
Perhaps they're still recovering from the Olympics so long ago... :dizzy:
Perhaps you should have sent your request with a "Dear sirs..." instead of an "Hola, pinche cabrones..." :laugh2:
Or (Hey! Here's an idea!) hop a train and go there and get it!
grantspain
« Reply #4 on: April 26, 2007, 05:44:21 pm »
and my company wanders why i order all the spares from the u.k-2 days delivery and half the price
last week i got a quote for a convergence ic from a spanish company at 100 euro's(about the same in $)and a 2 week wait,the same ic delivered in 2 days from the u.k at 25 euro's :dunno
modessitt
  • Technician
« Reply #5 on: April 26, 2007, 10:10:18 pm »
Have them send you the 100 euro's, order the 25-euro one, then take the rest and hoist a few pints...  :cheers:
SirPeale
  • Green Mountain Man
« Reply #6 on: April 27, 2007, 12:47:33 am »
What's wrong with the old stick?
grantspain
« Reply #7 on: April 27, 2007, 02:41:28 am »
the plastic grips are broken inside so they just twist around the shaft,i tried using some good plastic filler to recreate the molding but to no avail.
once the customers start twisting the grip the wires break to the switches
modessitt
  • Technician
« Reply #8 on: April 27, 2007, 08:18:30 pm »
Hmm...had a Zaxxon do something similar....
Have you considered drilling holes through the grips and the shaft and running bolts through to keep them from twisting?  Or new holes if the current holes are stripped?
grantspain
« Reply #9 on: April 28, 2007, 02:58:38 pm »
this is such a crappy controller that the shaft is not wide enough to bolt through(it has 5 wires running through it),i have noticed that the game only seems to use 3 of the 4 buttons so this may give some cheaper alternatives-this a very annoying crap machine,its up there with belly bomber and crypt killer :angry:
Crowquill
  • Last login:November 21, 2024, 09:42:17 am
« Reply #10 on: April 28, 2007, 05:34:43 pm »
Is it something where you could just try to find a replacement handle? You might be able to find a PC flight stick with a similar diameter shaft. Or if you could possibly find a Happ or Suzo stick whose parts would work on yours and order just the parts of the handle.
I'm guessing you've already checked into this though.
modessitt
  • Technician
« Reply #11 on: April 29, 2007, 03:13:29 am »
Does Spain even have an Air Force???   ;)
Just alter the CP and put in a normal joystick with the buttons on the CP next to it.   They'll get used to it eventually....
modessitt
  • Technician
« Reply #12 on: April 29, 2007, 03:16:49 am »
BTW...
Tried to do a KLOV search for "rx-1" and similar and didn't find anything.  Wanted to see what the original looked like just in case I have something like it lying around the shop.....
grantspain
« Reply #13 on: April 29, 2007, 05:21:41 pm »
steve you're a genius mate ,i can get a 2 button stick and just add a button on the control panel and for poco monera,now why did'nt i think of that ::)
modessitt
  • Technician
« Reply #14 on: April 30, 2007, 01:17:01 am »
 :dunno
