Author Topic: Galaga and RAM 4h  (Read 5521 times)
Hawk Daddy
  • Last login:June 15, 2025, 03:10:44 pm
  • Only True Pimps Have Arcade Machines!!!
Galaga and RAM 4h
« on: April 23, 2007, 11:54:44 pm »
When I turned it on the first time tonight, it had ram 4h on the screen.  I turned it off then back on and it worked fine.  After a little research thats an error on the video pc board, where can I find a replacement 4h chip?
Hawk
Galaga Restored
Millipede Multicade
Donkey Kong JR.
Mortal Komba
Touchmaster
Steel Talons 2 player helicopter game
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re: Galaga and RAM 4h
« Reply #1 on: April 24, 2007, 10:59:32 am »
Check your voltages first.
NO MORE!!
Hawk Daddy
« Reply #2 on: April 27, 2007, 06:18:44 pm »
Voltages on what?  Now it doesn't even let me play it at all, I'm about to get fed up with this thing, and post a vid named Galaga vs.  Sledgehammer, cause I'm tired of putting money into a lemon.
Hawk
« Last Edit: April 27, 2007, 06:47:50 pm by Hawk Daddy »
Galaga Restored
Millipede Multicade
Donkey Kong JR.
Mortal Komba
Touchmaster
modessitt
  • Last login:October 17, 2021, 07:02:28 pm
  • Technician
« Reply #3 on: April 27, 2007, 08:32:35 pm »
Only a week and it's a lemon???
Here is what your error code means:
  RAM 4H  - RAM located on Video PC board at position 3J is bad
It's possible it IS bad.  the manual lists it as a "2114-2 ST. RAM 200NS.(1024X4)" and you should be able to get one.  Ask around, or contact some of the Galaga repair sites.
When he said to check your voltages, he mainly means your +5V as this is needed for the board to run, although they should all be proper for everything to work.
You can find out how, as well as other Galaga repair tips, here:
http://www.arcadeshop.com/galaga/galaga.htm
Working Games:Joust CT,Gyruss UR,Pong,Battlezone UR#1
Current Proj's:Battlezone UR#2
Cheap/Free Cabs Wanted: DK,KarateChamp,Shinobi,Ghosts&Goblins,CircusCharlie,10ydFight,PolePositnCP,RallyX,Frogger
Hawk Daddy
« Reply #4 on: April 28, 2007, 02:49:37 am »
It's 5v thats done been checked.
Hawk
Galaga Restored
Millipede Multicade
Donkey Kong JR.
Mortal Komba
Touchmaster
modessitt
  • Technician
« Reply #5 on: April 28, 2007, 02:17:37 pm »
5.00V?  I've seen some Galaga's that don't like to run unless it's between 5.10 and 5.20.  Don't take it over 5.20, though, as Galaga's can be especially sensitive.
Try reseating your 3J chip on your Video PC board (if it's socketed) or contact some Galaga repair sites for either a new chip, or for you to send them your board....
Level42
« Reply #6 on: April 28, 2007, 04:58:50 pm »
http://www.arcadechips.com/product_info.php?products_id=35
Surprise surprise it's the #2 selling item in the RAMs section.
modessitt
  • Technician
« Reply #7 on: April 29, 2007, 03:09:51 am »
And for $1.60 a pop, it's worth buying a couple just in case you have another problem with the board and lose the new chip once it's powered up....
Hawk Daddy
« Reply #8 on: April 29, 2007, 05:05:20 am »
Ok thanks, I'll order me 2 or 3 of them tomorrow and see if that fixes it.
Hawk
Galaga Restored
Millipede Multicade
Donkey Kong JR.
Mortal Komba
Touchmaster
Hawk Daddy
« Reply #9 on: April 29, 2007, 04:13:32 pm »
What other ram chips would be good to pick up just incase for this thing?
Hawk
Galaga Restored
Millipede Multicade
Donkey Kong JR.
Mortal Komba
Touchmaster
Hawk Daddy
« Reply #10 on: April 29, 2007, 09:35:35 pm »
Well I unplugged the chip and then replugged it and it worked fine for now.  I'll see what happens tomorrow and see if that was the problem.
Hawk
Galaga Restored
Millipede Multicade
Donkey Kong JR.
Mortal Komba
Touchmaster
RayB
  • There's my post
    • RayB.com
« Reply #11 on: April 30, 2007, 01:59:34 pm »
« Last Edit: April 30, 2007, 04:53:20 pm by RayB »
NO MORE!!
SirPeale
  • Green Mountain Man
« Reply #12 on: April 30, 2007, 04:20:19 pm »
I think he just hit the nail on the head; I wasn't aware that this chip was socketed.  Since he reseated it, it's come back to normal operation.
Press down lightly on the rest of the socketed chips.  You may hear some crackling.  That's normal, the chip going back down into the socket.  It's called 'creep' and it results from thermal expansion and contraction.
Next, get yourself a Pink Pearl eraser (yes, it's an actual brand name, don't settle for anything less) and clean the edge connector on the PCB.  Both sides.  Go *with* the contacts, not against them, or you might peel them off.  Likely you'll see the eraser turning grey or black.  That's the crud coming off the connector.  Make sure you wipe away the eraser particulate.
Finally, check your voltage on the PCB, just behind the harness.  Adjust it to ~5.18V.
