Author Topic: Isolation transformer  (Read 5442 times)
chris79
  • Last login:September 07, 2007, 03:25:14 pm
« on: April 20, 2007, 02:46:39 pm »
If your installing a new monitor that does not require an isolation transformer in an arcade cabinet where the previous monitor needed an isolation transformer.  Do you have to remove the isolation transformer?
shardian
Re: Isolation transformer
« Reply #1 on: April 20, 2007, 02:49:26 pm »
You don't really have to remove it from the cab. You can just disconnect it from the live wiring.
grantspain
« Reply #2 on: April 20, 2007, 02:50:21 pm »
you can still use it if the voltage is correct
chris79
« Reply #3 on: April 20, 2007, 03:02:36 pm »
ok i'm thinking about replacing my electrohome g07 with maybe a wells gardner k7700 in my galaga cabinet I'm just hoping there isn't any problems with leaving the transformer hooked up but if there's a risk maybe it would be best to unhook it
grantspain
« Reply #4 on: April 20, 2007, 03:10:01 pm »
it would be like removing an extra piece of protection and i thought the wg7000 series need an iso tranformer
chris79
« Reply #5 on: April 20, 2007, 03:14:20 pm »
there K7700 and K7200 do not need a transformer but there K7000 do I wouldn't think there be any harm leaving it there the monitor i'm putting is the same size and specifications
grantspain
« Reply #6 on: April 20, 2007, 03:17:42 pm »
i can't see how you could damage the monitor but if you want to be 100% sure drop ken layton a pm,he's the expert on wg
chris79
« Reply #7 on: April 20, 2007, 03:20:28 pm »
ok thanks for input
SirPeale
  • Green Mountain Man
« Reply #8 on: April 20, 2007, 04:00:52 pm »
Absolutely not!  Feel free to leave the iso in the cabinet.  Though your new monitor doesn't require it, there may be a time in the future that you'll need the isolation.  It'll be there if you do.
Let me put it another way: using an iso transformer on a monitor that doesn't require it won't hurt the monitor in the slightest, but the other way around will kill your monitor.  Use it with no worries.
chris79
« Reply #9 on: April 20, 2007, 04:34:53 pm »
thanks I figured that I just wanted to confirm it I guess newer monitors have the isolation transformer built into the chassis I guess
Ken Layton
  • Guru
  • Technician
« Reply #10 on: April 20, 2007, 05:55:30 pm »
Hold on thar! You're replacing an Electrohome 19" horizontal (shelf) mount monitor with a Wells-Gardner 9" horizontal (shelf) mount monitor?
The 7700 is a 9" horizontal (k7000) and it requires an isolation transformer.
chris79
« Reply #11 on: April 22, 2007, 03:10:24 pm »
sorry I had the wrong number it's a D7700
here is the model number WGE1977-H0GS39R
Ken Layton
  • Guru
  • Technician
« Reply #12 on: April 22, 2007, 06:27:06 pm »
And after reading about all the trouble with Wells-Gardner monitors (especially the "digital" ones), you're still going to buy one?
chris79
« Reply #13 on: April 22, 2007, 06:54:36 pm »
well I have not made up my mind. I am thinking of buying a Vision Pro Monitor Mikes arcade sells one with a cocktail mounting frame.  I posted a topic asking if Vision Pro monitors are any good.
I take it all of Wells gardner new monitors are equally as bad?
i'm seriously considering Vision Pro now I just hope there not bad.
I appreciate your time if you have any advice or suggestions i'm open to them.
thank you Chris
