Author Topic: Jamma Tester (Pics)  (Read 5843 times)
BobA
  • What Me Worry?
Jamma Tester (Pics)
« on: April 18, 2007, 05:18:42 pm »
Thought I would post pics of my jamma tester just for interest.   Not big enough for the projects section.
It is built in a 8 inch W 3.5 inch H 5.5 inch D Handibox
The largest part of the box is a Vss 001 power supply from Sony 5V 7A, -5V 1A, +12V 1A
It has service. test, tilt and power switches on the front and 3 DB 15 connectors on the back to connect modified gamepads or
a button/joystick tester and an RGB monitor.  The RGB monitor is an Applecolor 12 inch RGB. A speaker is also mounted
in the box.
Total Cost to build including getting the Apple monitor at a Goodwill Shop approx  $100.
Witchboard
Re: Jamma Tester (Pics)
« Reply #1 on: April 18, 2007, 10:59:26 pm »
That's compact.  How hot does it get when used extensively?
BobA
  • What Me Worry?
« Reply #2 on: April 19, 2007, 10:52:03 am »
Just warm enough to know it is on.  The case has vent holes all arount the back of the top cover and the supply is vented and where it sits in the metal case it transfers heat to the case where the vent holes on one side are blocked due to the mounting.
Level42
« Reply #3 on: April 19, 2007, 04:24:18 pm »
I gotta build me something like this. Very nice but I'd like to include a tiny monitor. There are really small TV sets for camp-site use here that have SCART so those would be ideal.....
I'd also need adapters to go to non-jamma boards.
BobA
  • What Me Worry?
« Reply #4 on: April 19, 2007, 05:26:45 pm »
I do have a 12 inch RGB monitor that I use but it connects separately to keep the box small.
Rocky
« Reply #5 on: April 19, 2007, 09:17:37 pm »
Nice work!
pointdablame
« Reply #6 on: April 19, 2007, 10:17:26 pm »
Very cool little project.  Nice Job!
first off your and idiot
Level42
« Reply #7 on: April 20, 2007, 01:31:59 am »
Yeah, the small TV's I meant are even smaller, 20 cm (Less than 10"). That could all be built into one box and still be rather small I guess.
BobA
  • What Me Worry?
« Reply #8 on: April 20, 2007, 09:08:07 am »
I would like a 7 or 8 inch LCD setup to use as a monitor.  It would be a great match for the Jamma tester and setting up CCTV.. Maybe the LCD from a broken portable  DVD player could be used with the proper mods.
BobA
  • What Me Worry?
« Reply #9 on: April 20, 2007, 09:09:41 am »
Rocky, Pointdablame
Thanks Guys. ;D
Witchboard
« Reply #10 on: April 20, 2007, 08:17:43 pm »
I used one of those PS1 LCD's in my JAMMA test rig.  Works great.
BobA
  • What Me Worry?
« Reply #11 on: April 21, 2007, 10:35:58 am »
Is a mod required for that or is there a way for direct RGB and sync on the PS1 LCD?
Witchboard
« Reply #12 on: April 21, 2007, 02:47:03 pm »
Here's the tutorial I used.  Just ran the sync and colors as they show them.
http://www.bit-tech.net/modding/2004/07/07/psone_lcd/1.html
knave
  • Last login:October 15, 2025, 04:12:19 pm
« Reply #13 on: April 24, 2007, 12:23:36 am »
So does that mean that regular LCDs cam be moded to accept jamma video signals?
BobA
  • What Me Worry?
« Reply #14 on: April 24, 2007, 05:25:07 pm »
Not yet.  Instructions are for the specific PS1 LCD only.   More small lcd displays are probably hackable but someone has to do the basic work to figure them out.
Level42
« Reply #15 on: May 09, 2007, 03:32:29 am »
Well, it will be close to impossible to use a "regular" LCD unless it has RGB analogue inputs, which is very very rarely the case.
LCD's are controlled totaly different then CRT's. LCD's don't require the syncing signals, since there is no electron-beam to move over the screen. The individual pixels are simply controlled directly, much like adressing a location in a memory.
knave
« Reply #16 on: May 09, 2007, 11:43:45 am »
Well, it will be close to impossible to use a "regular" LCD unless it has RGB analogue inputs...
So does this mean that the newer LCD TV's with component inputs (RGB) could be modded to work as an arcade monitor?
« Reply #17 on: May 09, 2007, 11:49:52 am »
Component is not RGB.
horseboy
  • Only Saint has those powers.
  • Last login:March 07, 2021, 02:19:14 pm
  • With my last breath, I curse Zoidberg!
« Reply #18 on: May 09, 2007, 12:47:47 pm »
Many of the smaller lcd screens can be modded for RGB input, most notably, the PSone screen.
Quote from: saint
saint is all powerful.
Apparently he is.
« Reply #19 on: May 09, 2007, 12:48:34 pm »
Probably because they were designed to potentially be directly connected to a console.
horseboy
« Reply #20 on: May 09, 2007, 12:54:12 pm »
Some of the third party GameCube and Xbox screens used the exact same lcd as the PSone screen, so there is a plethora of cheap screens out there that can be used for this purpose.
Quote from: saint
Apparently he is.
horseboy
« Reply #21 on: May 09, 2007, 12:54:32 pm »
whoops
« Last Edit: May 09, 2007, 12:56:24 pm by horseboy »
Quote from: saint
Apparently he is.
« Reply #22 on: May 09, 2007, 01:00:52 pm »
Ocean State Job Lots carries a small GC version for something like $50... no idea if that's current rate but it's there.
Level42
« Reply #23 on: May 09, 2007, 01:09:45 pm »
Exactly. There is (extra) conversion electronics required to transform the RGB and sync signals into somthing a BARE LCD understands.... I was talking loose-naked-bare LCD's here.
50 bucks is not bad to hack one of these babies....
knave
« Reply #24 on: May 09, 2007, 07:10:28 pm »
Doesn't it use Red green and blue colors?
AH!...A little research and it turns out it's both, But since I was thinking of the consumer standard which is not RGB I am corrected.
Quote from: Website
Definition of: component video
A video color format that maintains the three YUV video signals in three separate channels. Component video provides a sharper image than composite video and S-video. See YUV, composite video and S-video.
Analog Component Video
Component video may refer to "analog" component video (YPbPr), especially with regard to the Y, Pb and Pr cable connectors on devices such as DVD players, set-top boxes, receivers and TVs. See YPbPr.
Digital Component Video
Component video may refer to "digital" component video (YCbCr), which is the norm for tape formats such as MiniDV, DV and Digital Betacam. Digital component video (YCbCr) is also natively supported by many nonlinear video editing programs (NLEs). See YCbCr and chroma subsampling.
RGB: Digital or Analog
Sometimes, component video refers to RGB signals rather than YUV. It may refer to "digital" RGB, which is the native graphics format in the computer, and it is supported by all nonlinear video editing programs (NLEs).
Component video may also refer to "analog" RGB, especially with regard to a three-cable RGB attachment to a studio monitor or high-end video camera. See YUV.
