Author Topic: CPO question  (Read 1965 times)
Avalon
  • Last login:May 18, 2007, 09:18:56 am
CPO question
« on: April 18, 2007, 02:36:20 pm »
Hi everyone,
I'm new to this forum and I just decided to build a custom arcade joystick using a PS2 Dualshock2 hack (Doing this will make it compatible with almost any system with use of adapters) using the Mortal Kombat button layout (incl. the Run button).
I want it to be an exact replica of the MK arcade panel.  :)
This was the CPO I was aiming for:
It's a MK3 panel with additional 'run' buttons, only thing is that this type of CPO seems very hard to come by, so I decided to go for the MKII CPO.
This one is from mamemarqees.com and is covered with Polycarbinate laminate wich makes it rockhard and shiny too!  ;D
I've come across another MKII CPO on Ebay though, only without the Polycarbinate laminate covering and it's nothing more than a sheet of metal (with precut holes)
and the seller states that this is a very rare Item (eventhough he has two of them)
So, now for the question...
I'm quite indecisive when it comes to making my choice between the two CPO's
I was wondering if anyone here can tell me the front and backends of both these type of overlays?
Thnx you guys!
I'll post some pictures as I start building the stick..
Grtzz!
« Last Edit: April 18, 2007, 02:38:53 pm by Avalon »
Avalon
Re: CPO question
« Reply #1 on: April 18, 2007, 07:03:34 pm »
Total N00B here!  ;D
Help?  ???
 :angel:
Avalon
Re: CPO question
« Reply #2 on: April 20, 2007, 10:42:18 am »
I'm starting to think that I asked a very silly question?  :dunno
  • Last login:Yesterday at 05:09:27 pm
Re: CPO question
« Reply #3 on: April 20, 2007, 11:50:02 am »
Poor guy...
For me, I like the MKII CPO. Holds more memories. Add a run button and call it a day.
Avalon
Re: CPO question
« Reply #4 on: April 20, 2007, 12:49:10 pm »
Poor guy...
That wasn't really my question..  :applaud:
But thanks anyway!
« Last Edit: April 20, 2007, 12:51:01 pm by Avalon »
Re: CPO question
« Reply #5 on: April 20, 2007, 01:39:39 pm »
ah, my mistake.
Heres my experience so far:
Polycarbonite is nice. It sticks on and your done.
Non-poly needs to be covered with some plexi or something.
You say this is a metal CP with holes. What does that mean exactly? You have your CP and it needs the overlay? If so, go with the polycarbonite if you can. It'll apply directly to it, cut out the holes and your done. If you need to put a non-poly on it - you'll want to also figure out a way to attach some plexiglass.
How'd I do this time?  ;)
Avalon
Re: CPO question
« Reply #6 on: April 20, 2007, 04:44:23 pm »
The CPO itself is a metal sheet!
Come to think of it, I may go for the Polycarbinate laminated one, this way I just have to aply it to the panel instead of covering it with plexiglass, like you said..
This way it will have a nicer look without the plexiglass.
Thanks for your reply leapinlew !
« Last Edit: April 20, 2007, 04:46:48 pm by Avalon »
Re: CPO question
« Reply #7 on: April 20, 2007, 06:24:19 pm »
Really? Check it out... it's not a sticker on there?
Avalon
Re: CPO question
« Reply #8 on: April 22, 2007, 05:50:43 pm »
The guy selling this on Ebay says no..
He only ships within the US, so I asked him (before bidding) if he could make an exception, he agreed considering he had two of these..  :blah:
Anyway, It seems he changed his mind and totally screwed me over with his 'promise'
O well, time to order the Polycarbinate laminated one from mamemarquees !!   ;D
« Last Edit: April 22, 2007, 05:53:31 pm by Avalon »
