Author Topic: Using an earlier version of Mame  (Read 1168 times)
bigredsk10
  • Last login:March 03, 2012, 03:45:20 pm
« on: April 17, 2007, 05:02:05 pm »
I am relatively new to Mame but I recently downloaded and set up Mame with Mala as my front end. I used the most recent version of Mame, 0.114, because I did not know any reason not to.
My computer is 1.79 ghz and I have had some slow down with a number of games, such as NBA Jam.  I have a couple of questions.
Would using an earlier version of Mame fix the slow down problems? If so how far back would you recommend I use?
If I used an earlier version of Mame would I have to have an all new set of roms?
Thanks for your help!
ark_ader
  • I glow in the dark.
Re: Using an earlier version of Mame
« Reply #1 on: April 17, 2007, 05:08:55 pm »
.84 is good especially for the spec.
TOK
  • The Game Always Wins
« Reply #2 on: April 17, 2007, 06:03:07 pm »
If Golden Tee Golf is important to you, its in version .99. That version also fixed a speed issue with Robotron and also still supports the old hiscore.dat file (high score saves) so it's the version I use.
MAME started really going downhill fast speedwise in the .1xx versions.
bigredsk10
« Reply #3 on: April 18, 2007, 05:51:45 am »
That helps a lot, most speed problems I was having were fixed. I went with .84 cause I built my arcade machine as cheap as I could and didnt include a trackball.
Thanks a lot!
