Author Topic: Cabinet Repair  (Read 2097 times)
markt
  • Last login:May 08, 2010, 07:48:50 pm
Cabinet Repair
« on: April 14, 2007, 10:32:10 pm »
I wasn't sure if I should post this here or in woodworking.
I have a cab with some missing chunks of wood on the corners by the c.p.
What is the best way to fill this in?
Wood putty, bondo, construction adhesive??
grantspain
  • Last login:Yesterday at 05:26:50 pm
Re: Cabinet Repair
« Reply #1 on: April 15, 2007, 04:31:17 am »
i use car filler as you can mould it just before it goes off
Rocky
Re: Cabinet Repair
« Reply #2 on: April 15, 2007, 03:35:59 pm »
Bondo
modessitt
  • Last login:October 17, 2021, 07:02:28 pm
  • Technician
Re: Cabinet Repair
« Reply #3 on: April 15, 2007, 07:36:06 pm »
YES, Lowe's sells a wood filler by bondo.  Mix it and shape it in, a little bigger than you need, then use a palm sander to make it even with the sides after it cures.  Once painted it looks great!
I did this on a Frogger cab that someone dropped and broke a 3 inch section off the top corner.  Molded it to the right shape and sanded and painted.  Used a sutting wheel to make a grrove for t-molding.  After it was painted you couldn't tell it wasn't original.
Working Games:Joust CT,Gyruss UR,Pong,Battlezone UR#1
Current Proj's:Battlezone UR#2
Cheap/Free Cabs Wanted: DK,KarateChamp,Shinobi,Ghosts&Goblins,CircusCharlie,10ydFight,PolePositnCP,RallyX,Frogger
RichSorr
  • Last login:August 29, 2015, 07:27:00 pm
Re: Cabinet Repair
« Reply #4 on: April 16, 2007, 12:30:31 am »
fredster
  • It's all good!
Re: Cabinet Repair
« Reply #5 on: April 17, 2007, 05:26:10 pm »
Bondo
BONDO.  There are several places on the net you can find a walkthrough on this.  Randy Fromm has a cabinet repair video.  Ask around (to ChadTower) and see if you can find one of those tapes....
