Author Topic: HELP - With Cabinet Audio Needed  (Read 954 times)
Freeplay
  • Last login:May 02, 2015, 06:04:19 pm
  • I'll be crosses !
« on: April 14, 2007, 07:06:42 pm »
I’m in the middle of a Jukebox cab build. ( PC based PIII, SKjukebox, keywiz etc )
My dilemma starts with the audio.  I’m  installing a sub woofer box, and some 6x9 4 way car speakers for the top end sound.
I can get these from ebay fairly cheap.
I want to keep it all running from mains power ( 240v Aussie )
So do I need to find an Amp that has 2.1 channel output... or is there a way of connecting the sub to a 2 channel Amp?
"The Best Thing About Getting Old"
You can afford bigger and better toys
BobA
  • What Me Worry?
Re: HELP - With Cabinet Audio Needed
« Reply #1 on: April 14, 2007, 08:58:41 pm »
You are using automotive type speakers so it would probably be easiest to connect them up to a automotive amp.   Make sure you don't get too many watts as it becomes hard to find a large enough power supply.   I think the common setups are for a multi channel amp that does 2 channels and the sub or a 2 channel amp and separate amp for the sub.
