Author Topic: Mala Filter/List Help  (Read 3833 times)
twitami
  • Last login:December 22, 2016, 01:09:08 pm
« on: April 14, 2007, 06:28:22 pm »
Is there a way in Mala to have Gamelists based on controller types? I see it in filters, but that doesn't seem to work the way I want it too. I have 5 different control panels that i made for my cab, and I simply want to be able to switch between Gamelists from within Mala to select the correct games, like All Trackball Games, All Dual Joystick Games, etc. Anyway to do this (I hope so, because everything else I want Mala does SO well...what a great FE!
Thanks,
Brian
loadman
  • Moderator
    • MaLa
Re: Mala Filter/List Help
« Reply #1 on: April 14, 2007, 07:09:34 pm »
You use MaLagamelist.exe to create your custom lists..
see attached pic
« Last Edit: April 14, 2007, 07:21:20 pm by loadman »
squirrellydw
  • Last login:April 12, 2021, 11:30:22 am
« Reply #2 on: April 14, 2007, 09:30:35 pm »
whats the difference between dial and paddle?
I b**ch. People listen!!
