Author Topic: Slightly bizar request, wanted to buy or trade  (Read 1519 times)
bfauska
« on: April 14, 2007, 04:52:18 pm »
I know that most people would just throw this away if they only had one, so I figure it is worth asking.
I also know that I can buy a pair for very little money...
I am looking for a Coin Controls coin door lock #cc019.  I am a cheap bastard and I have one and the keys but I have an over/under door, so I need two.  I also figure it is better than adding another little but useful thing to a landfill.
If anybody around here happens to have a matching lock because you are a pack rat like myself and would like to sell it or give it or trade it with me let me know.  I have some joysticks from an NBA Jam, I have access to tools and plexi if you need a little for a CP or Marquee, I have the ability to custom build stuff, although I think that would require a little more than the lock in trade.
Mostly I figured this is a silly request, but rather than me throw away my lock and 2 keys and somebody sit on a lock that they may not have keys for I thought I might as well ask.  What's the harm?  A little bandwidth and a nice place for somebody clever to come up with a good way to mock the request.
Thanks,
Brian
bfauska
Re: Slightly bizar request, wanted to buy or trade
« Reply #1 on: April 14, 2007, 07:24:34 pm »
Sounds promising, I'll give that a shot if I find a similar lock, the keys look fairly standard as far as the grooves on the side go.
knave
  • Last login:October 15, 2025, 04:12:19 pm
« Reply #2 on: April 16, 2007, 12:09:13 pm »
Use needle nose pliers to yank out all the brass tabs that aren't sitting flush with the assembly when your key is inserted.
Couldn't you use a dremmel to cut them flush as well...?
« Reply #3 on: April 16, 2007, 12:15:02 pm »
You could, but in home use, the lock is almost irrelevant anyway, so it's not really worth doing.
« Reply #4 on: April 18, 2007, 01:42:23 pm »
I was thinking he meant to pull the tab out and dremel off the bottom part, not the part with the tab that stops it from falling in.
