Author Topic: help finding button  (Read 1113 times)
boodroe
  • Last login:October 24, 2024, 02:16:02 pm
help finding button
« on: April 09, 2007, 07:01:26 pm »
Does anyone know where I can find this case and button? I need both the case and the button. I need something almost identical. Iv looked on the internet and havent found anything similar. Thanks for the help.
« Last Edit: April 09, 2007, 07:04:22 pm by boodroe »
Hello, 911? It's Quagmire. Yeah, it's caught in the window this time.
BobA
  • What Me Worry?
Re: help finding button
« Reply #1 on: April 09, 2007, 07:25:32 pm »
Looks like a small plastic project case with PB mounted with protection sleeve and LED.   Does your case have to have the mouting tabs?   Is it weatherproof? What are the exact measurements of the case.?   I think you will have to fabricate something close unless you know exactly where the button/led assembly came from.
boodroe
« Reply #2 on: April 09, 2007, 07:29:37 pm »
Im not sure where it came from, but I would like to find someone who sells it instead of fabricating it. It is for a project at work, i was just checking to see if some of you button experts can help me out  ;D
BobA
  • What Me Worry?
« Reply #3 on: April 09, 2007, 07:35:33 pm »
The button looks like a simple PB that you can find at Radio Shack as does the LED mount.  I don't think anyone would stock such an item but there are fabricators who would charge you a bunch to custom assemble them for you.    Do you need the tabs on the case?
boodroe
« Reply #4 on: April 09, 2007, 11:38:34 pm »
yes, i need something pretty much identical
BobA
  • What Me Worry?
« Reply #5 on: April 10, 2007, 12:39:27 am »
If you need tabs on the case you probably will have the biggest problem sourceing the case unless someone else knows where to get them. You are not providing exact info on what you need.   Like switching capacity is the PB low voltage or line voltage.   Is it momentary or switched? How many amps or milliamps does it need to handle? It looks like a setup for a motor starter but I am only guessing at what you are doing. What is the exact size of the case you need? Not many people can find a case for you if they don't know at least the approx size.
Good luck.
