Author Topic: Best way to mount USB ports to cab?  (Read 3296 times)
displacedtexan
  • Last login:August 20, 2007, 11:13:38 pm
« on: April 08, 2007, 04:09:42 pm »
So, what's the prettiest way to mount USB ports to allow USB access from outside your cab?
I have searched the forums and these seem to be the two best options:
http://www.frontx.com/order2.html
http://www.switchcraft.com/products/560.html
Anybody have any better suggestions?
Thanks!!
BobA
  • What Me Worry?
Re: Best way to mount USB ports to cab?
« Reply #1 on: April 08, 2007, 04:37:26 pm »
These take up less space and plug into your USB port on the computer not directly to the MB.   Easier to get longer extentions depending on your USB connector placement.
USB Panel Connectors
bfauska
« Reply #2 on: April 08, 2007, 11:25:46 pm »
I just got a 2' version of the cable BobA shows from a PC recycling place here in Seattle, it was actually built into a computer component, but the whole assembly only cost me $1 and it also had a firewire cable of the same style.  Definitely worth looking for a place like this near you, even if they don't have the exact same part they may (like this one did) have bins of used cables and headers that are really cheap and good for making adapters out of.
DrumAnBass
  • Last login:July 10, 2024, 10:36:54 pm
  • "I love this computer magic!" - Viv Savage
« Reply #3 on: April 09, 2007, 02:00:01 am »
I am using a 3.5" "Media Dashboard"  - basically a little plastic box with a 4 port USB 2.0 hub as well as audio I/O and FireWire, Ultra Products ULT33067.
« Last Edit: April 09, 2007, 02:02:18 am by DrumAnBass »
"Some drink from the fountain of knowledge; I only gargle."
squirrellydw
  • Last login:April 12, 2021, 11:30:22 am
« Reply #4 on: April 09, 2007, 10:00:50 am »
the switchcraft plugs have a mounting plate you can use, I have one and it works great.
I b**ch. People listen!!
MustardTent
  • Last login:February 22, 2015, 12:14:02 pm
    • Blog
« Reply #5 on: April 09, 2007, 10:03:00 am »
I have two of these mounted on the underside of my CP with a datapro faceplate.  If you're interested, I can take a picture when I get home later.
Kaytrim
  • I'm too nice a guy
« Reply #6 on: April 09, 2007, 12:55:21 pm »
What are the prices for the switchcraft stuff??  They are not on their website.
TTFN :cheers:
Kaytrim
DrumAnBass
« Reply #7 on: April 09, 2007, 01:21:07 pm »
For prices on switchcraft stuff, see: http://www.markertek.com/
crpngdth2001
  • Last login:April 30, 2007, 10:16:12 am
« Reply #8 on: April 09, 2007, 02:12:45 pm »
I'm using this faceplate along with the panel mount usb cables that go to the motherboard headers:
http://www.datapro.net/products/73202.html
displacedtexan
« Reply #9 on: April 10, 2007, 01:43:31 pm »
crpngdth2001,
Did you buy the black or the aluminum?  If the aluminum, does it have datapro's lettering on it?
Thanks!!
ahofle
    • Arcade Ambience Project
« Reply #10 on: April 10, 2007, 03:53:49 pm »
Another vote for the switchcraft USB barrel mounts in black.  Installation is simple and only involves drilling a single hole.
Jake
  • Last login:April 22, 2009, 02:42:37 pm
    • My webpage
« Reply #11 on: April 11, 2007, 12:57:06 pm »
Slightly off topic.....thanks for posting that link to Frontx.  They had the female crimp connectors that I was having such a hard time finding.  1.20$ and free shipping. :cheers:
Level Designer - Virtual Heroes
http://www.virtualheroes.com
