Author Topic: Mala and Screen Resolution Issue - RESOLVED  (Read 6893 times)
WLVRYN
  • Last login:December 15, 2008, 02:03:52 am
« on: April 06, 2007, 02:29:48 am »
I'm about to put my computer through my TV because of this, so hopefully someone can help me out.  I'm leaning towards this being a software problem rather than a monitor/video problem, so I posted this here.
I'm running the latest version of Mala (RC9) and am using an ATI Radeon 9550 video card connected to a 27" Insignia TV through component using the DVI-Component adapter.  Through the Catalyst Control Center, I have set the Windows XP resolution to 640x432.  Windows seems to work fine at that res, and I'm getting a decent picture.  Whenever I start Mala though, it changes the resolution to 640x480.  I then get my layout and many of my games (especially the vertical games) get cut off on the top and bottom.  I have set the custom resolution in MAME to 640x432, so I'm not sure why its running the games at 640x480.  As soon as I close Mala, Windows goes back to 640x432.  If I run any games (even vertical ones) from the MAME command line, it runs perfectly right on the edges of the TV and nothing gets cut off.
After all that, my question is, is there a way to not have Mala change the resolution to 640x480?  I'm sure that I'm missing something easy, but this is driving me nuts.  Thanks in advance.
« Last Edit: April 06, 2007, 10:05:10 pm by WLVRYN »
loadman
  • Moderator
    • MaLa
Re: Mala and Screen Resolution Issue
« Reply #1 on: April 06, 2007, 02:35:18 am »
What layout are you using?
WLVRYN
« Reply #2 on: April 06, 2007, 02:38:47 am »
I have tried a bunch of different layouts, but at the end of the day I just used the standard layout (with no background picture - just a blue screen for now) and have added/removed a few of the text boxes.  I also added in a snaps box, but that's about it.
I thought it might be a layout issue at first as well, but I dont think I'm using a fixed layout with the standard one, so I discounted that as a problem.  Maybe that is my problem.
loadman
  • Moderator
    • MaLa
« Reply #3 on: April 06, 2007, 02:49:17 am »
Hi
Here are my Settings...
I don't know how to set-up a TV as a Mame display but I know of othere that have used Low-Rez Arcade monitors with Mame/MaLa
WLVRYN
« Reply #4 on: April 06, 2007, 01:14:56 pm »
Thanks Loadman, but that didnt help.
I'm going to cross post this in the monitor forum to see if I can get some help there too.
loadman
  • Moderator
    • MaLa
« Reply #5 on: April 06, 2007, 07:57:35 pm »
Good Idea  ;)
WLVRYN
Re: Mala and Screen Resolution Issue - RESOLVED
« Reply #6 on: April 06, 2007, 10:05:55 pm »
I didnt get any help over there, so I just uninstalled and reinstalled MaLa using the 640x432 resolution and it seems to work fine now.
