Author Topic: metal cutting,HOW ? + simple t-molding question.  (Read 2295 times)
SNAAAKE
  • -Banned-
« on: April 12, 2003, 03:15:35 pm »
Anyone know how I could cut piano hings?
Snif?  ???
Any other solution anyone?
I hear there are jigsaw blade that I could use.Anyone ever tried jigsaw for metal cutting?
Thanks in advance for any help ;D.
Yes I have this piano hing thats 40" and I only need like 26".
Also,never routed 5/8 wood.what size sloting bit do I use...1/16?
Just wanted to make sure..since the wood is thin..
« Last Edit: April 12, 2003, 03:21:47 pm by SNAAAKE »
OSCAR
    • Oscar Controls
Re:metal cutting,HOW ?
« Reply #1 on: April 12, 2003, 03:19:16 pm »
With a metal cutting blade, a jigsaw will work perfect.  Don't use a wood blade, though, or it will be a rough way to go.  A metal cutting blade will be somewhere around 32TPI, I think.  Mine isn't handy at the moment, but I'm sure someone else can say for sure.
shmokes
  • Don't tread on me.
    • Jake Moses
« Reply #2 on: April 12, 2003, 03:20:21 pm »
Yeah, I was thinking jigsaw would be the way to go there.  Tin snips would also be a simple way to do it, but it would probably be a pretty ugly cut.
Best Kid iPad Apps
Brax
  • Last login:January 06, 2009, 09:03:48 am
  • Bring on the power tools!
Re:metal cutting,HOW ? + simple t-molding question.
« Reply #3 on: April 12, 2003, 04:00:46 pm »
Hacksaw and a file to clean it up after.
I'd be afraid a jigsaw blade would break and take your hand off!
It'll take about 6 firm strokes with a hacksaw to get through a piano hinge. Piece of cake.
I used a 1/8" slot cutting bit for my t-moulding in 5/8" wood and it worked fine. (hotglue to keep it in place) A 1/16" bit is optimum and it'll be plenty strong. No worries.
« Last Edit: April 12, 2003, 04:02:58 pm by Brax »
If you build a frankenpanel, chances are I don't care for you as a person.
SNAAAKE
  • -Banned-
« Reply #4 on: April 12, 2003, 04:54:16 pm »
Thanks for the reply :).
I was wondering if you actually did cut metal using jigsaw?
Did ya?
Just wanna make sure...
Brax,I dont know about handsaw...really works..?
I will go to home depot now and buy both hand saw and metal cutting jigsaw blade to see which works for me.
OSCAR
    • Oscar Controls
« Reply #5 on: April 12, 2003, 05:17:02 pm »
Did ya?
Yes, of course.  Many times.  In fact, that's pretty much all I use my jigsaw for.  See the piano hinge here,  http://www.skum.org/bartop/finish.htm, I cut that one with my jigsaw.
Brax
« Reply #6 on: April 12, 2003, 05:52:49 pm »
Did ya?
HACKsaw. Yup, it will work. A piano hinge is practically tin. It'll cut through it like butter. Either will work fine.
« Last Edit: April 12, 2003, 05:54:51 pm by Brax »
