Author Topic: Wells Gardner model 25k7193 -> horizontal position problems  (Read 2205 times)
dldogg
  • Last login:April 23, 2007, 10:39:56 am
« on: April 05, 2007, 10:47:07 am »
 :banghead:
Okay, I'm having a problem with my Wells Gardner model  25k7193 arcade monitor from an original X-MEN VS. STREETFIGHTER cabinate.
The problem is this: When I hook up my computer directly to the board it displays two desktops side by side. With the resolution at 600 x 480 60Hz
I have tried several combinations of screen resolutions (i.e. 300 x 200)  and still no results.
Also horizontal position adjustment on board only adjusts where it splits the two images. I am always left with a 2" gap between them.
Is this a result of setting it to 600 X 480 60Hz?
Could this some how damage my monitor?
What is the best way to fix this problem so I can run my CPS-2 games from Mame?
Would Ultimarc's ArcadeVGA fix this?
 :notworthy: Thanks for any help.  :notworthy:
« Last Edit: April 05, 2007, 10:41:57 pm by dldogg »
Ken Layton
  • Guru
  • Technician
Re: Philips M08x
« Reply #1 on: April 05, 2007, 11:45:06 am »
dldogg
Re: Wells Gardner model 25k7193 -> horizontal position problems
« Reply #2 on: April 05, 2007, 10:35:58 pm »
Thanks I corrected the original post.
SirPeale
  • Green Mountain Man
« Reply #3 on: April 06, 2007, 12:34:05 am »
That's easy; you're feeding a 31KHz signal to a monitor that's expecting 15KHz.
dldogg
« Reply #4 on: April 06, 2007, 09:21:56 am »
Thanks! I will try it
