Author Topic: windows resolution issues(same question as main forum)  (Read 1554 times)
polaris
  • veni vidi congai
« on: April 03, 2007, 05:39:03 pm »
hi everyone
guess i shoulda asked here rather than in the main forum being as it seems a software issue, doh.
i was changing my desktop display resolution to run mame 32 better.
clicked on desktop properties etc and was initially only given two options ,the standard vga one (1024x768) and another of 800x600 which i changed it to.
when i moved to change it back i was given loads more size options (all higher) and i changed back to what i had first, now basically different parts of my desktop are at different resolutions.
any help would be much appreciated ,its really doing my head in
(sorry if the numbers arent exact theyre from memory)
david656
  • Last login:June 01, 2017, 10:06:24 am
  • Big Man!
Re: windows resolution issues(same question as main forum)
« Reply #1 on: April 05, 2007, 08:53:10 pm »
r u using xp?
polaris
  • veni vidi congai
« Reply #2 on: April 05, 2007, 08:53:42 pm »
yep
david656
  • Big Man!
« Reply #3 on: April 05, 2007, 08:55:55 pm »
well wat about defaulting???
right click ur desktop go to properties it should open to themes and if you look it might say modified theme wellllll go to windows xp on the drop down and click apply
polaris
  • veni vidi congai
« Reply #4 on: April 05, 2007, 09:01:43 pm »
you say that like i should know what it means ;)
that worked , cheers
david656
  • Big Man!
« Reply #5 on: April 05, 2007, 09:11:01 pm »
oo soo its all fixed???
