Author Topic: Help Using MALA  (Read 6130 times)
MARINE1142
  • Last login:July 02, 2009, 03:00:59 pm
Help Using MALA
« on: April 01, 2007, 04:13:31 pm »
I m running v1.0 rc7 and some roms just dont work they dont come up on the list or are playable any ideas why. Games like starwars triliogy and mortal kombat 4 or streetfighter vs capcom?
« Last Edit: April 03, 2007, 03:51:24 pm by MARINE1142 »
SGT
  • Last login:May 31, 2025, 10:10:32 pm
Re: Help With Roms
« Reply #1 on: April 01, 2007, 04:35:16 pm »
I m running v1.0 rc7...
What is this?  Mala v1.0 rc7?  If the games are not showing up in Mala, right click in Mala and choose refresh game list.
If they are showing up, but not running, in the Mala configuration change the Mame window state to normal instead of hidden.  That way you will get a black command window that will show what problem Mame is having with the rom?  Possibly missing files in the rom.
Do the roms run okay when not using Mala and just running Mame from the command line? What version of Mame are you using? If this is Mala you are talking about, I would put Mala in the subject line so that it catches Loadman's attention.
« Last Edit: April 01, 2007, 04:41:29 pm by SGT »
MARINE1142
Re: Help With Roms Using MALA
« Reply #2 on: April 01, 2007, 04:49:40 pm »
I dont know how to change mame state to normal instead of hidden. The roms dont show up when i refresh the list. Also I dont know how to run the mame from the command line with out MALA.
SGT
Re: Help With Roms
« Reply #3 on: April 01, 2007, 05:08:32 pm »
Right click in Mala and choose options.
On the Mame Config Tab:
   Choose the Additional Tab
   Change the window state to normal
Do you mean in the "All Games" list or is this a list that you have created? If its a new list that you have created, you will need to right click with the game selected in the "All Games" list and choose "add game to list"
If you mean it doesn't show up in the All Games list, you may need to go to Mala options in the Basics tab under Mame Config and create the XML file.
You should be using the command line version of Mame.  What is the version number of Mame that you are using?
I would definitely modify the original post and add Mala to the subject line so that the guru, loadman, will see this post.
« Last Edit: April 01, 2007, 05:15:39 pm by SGT »
MARINE1142
« Reply #4 on: April 01, 2007, 05:14:03 pm »
This is for the all games list. What do you mean create a XML file? I did changed the post to include MALA. Thanks for you help.
SGT
« Reply #5 on: April 01, 2007, 05:18:20 pm »
Instructions are in the previous post.  Click the create button beside the XML line of the Mame Config->Basics Tab.
Have you already installed Mame?  Are some roms showing up in the All Games list?  If so, do some of them work?
« Last Edit: April 01, 2007, 05:20:44 pm by SGT »
MARINE1142
« Reply #6 on: April 03, 2007, 03:50:28 pm »
MALA works I can play all the games that are listed, but when I go to the folder that says roms for mame where the other roms are at and I add a rom like street fighter vs capcom then go to the mala list and refresh game list it never appears on the list? Any idea why?
Buddabing
Re: Help Using MALA
« Reply #7 on: April 04, 2007, 09:29:42 am »
Some games that you mentioned, such as Star Wars Trilogy and MK4, are not playable. You might see if there is a filter option to remove non-playable games.
Please read the wiki!
MARINE1142
Re: Help Using MALA
« Reply #8 on: April 09, 2007, 01:13:40 pm »
When you say the are none playable is that because of my set up or I need some other program to run these games or are there diffrent versions?
SGT
Re: Help Using MALA
« Reply #9 on: April 09, 2007, 01:20:26 pm »
Not successfully emulated yet.  You can lookup games and check the driver status here:
http://www.mameworld.net/maws/
MARINE1142
Re: Help Using MALA
« Reply #10 on: April 09, 2007, 07:17:35 pm »
The games show up on that site, does that mean it is available. Also is there a MALA manual or cheat sheet that tells you how to set it up use set up windows, options, and info.
SGT
Re: Help Using MALA
« Reply #11 on: April 09, 2007, 08:01:32 pm »
No.  As I mentioned in my last message:
The driver status for those two games says "Preliminary" which means they are not yet working.
http://mala.arcadezentrum.com/help.html
http://wiki.arcadecontrols.com/wiki/Mala_Wiki
« Last Edit: April 09, 2007, 08:11:24 pm by SGT »
squirrellydw
  • Last login:April 12, 2021, 11:30:22 am
Re: Help Using MALA
« Reply #12 on: April 09, 2007, 09:12:28 pm »
What version a MAME are you running?
Check this thread it might help
http://forum.arcadecontrols.com/index.php?topic=56010.0
or this
« Last Edit: April 09, 2007, 09:14:22 pm by squirrellydw »
I b**ch. People listen!!
