Author Topic: Panel Clamps from Happ. How to...  (Read 1400 times)
rdowdy95
  • Last login:July 29, 2011, 11:48:50 am
  • This is my rifle.
« on: March 30, 2007, 10:48:00 am »
I am going to be putting the control panel on the Arcade this weekend, and wiring some more stuff.  My question is on the panel clamp I am going to be attaching the spring loaded part to the inside of the cabinet side.  Now I know I will prolly attach the part to the control panel bottom first.  Then use those as my guides when I attach the spring loaded part.  Now once I am ready to put the spring loaded part after I line it up should I drill the holes for it about an 1/8" further down that way it will hold it more tightly?
Hopefully this weekend I can clean the room that my machine is going to be going in.
Kaytrim
  • I'm too nice a guy
Re: Panel Clamps from Happ. How to...
« Reply #1 on: March 30, 2007, 11:59:23 am »
Good question.  I'd like to know the answer as well.
rdowdy95
  • This is my rifle.
« Reply #2 on: March 30, 2007, 03:13:32 pm »
bump anyone use these before?
spacies
« Reply #3 on: March 30, 2007, 05:57:34 pm »
If its what I think they are then try this:
Attach the catch to your CP.
Then put the 'hook' through the catch and using a marker pen, mark the 4 holes against your cab.
Screw the clasp to your cab.
Have a test and if you need too, bend the spring loaded bit to adjust tension.
If you screw it down too far then it may not reach the catch.
Well, thats what I do anyway.
Hope it helps.
WLVRYN
  • Last login:December 15, 2008, 02:03:52 am
« Reply #4 on: April 01, 2007, 03:03:19 am »
Dowdy-
Did you hook these up yet?  I'm probably putting mine on tomorrow and would like to hear your results.
TIA
Xiaou2
  • Last login:Yesterday at 12:31:56 pm
  • NOM NOM NOM
« Reply #5 on: April 01, 2007, 07:13:50 am »
Place the two halves together, to get the proper alignment.  Mark the screw hole positions lightly.
However, you do not want to use the bottom set of those markings.  Instead, you want to mark something like
3mm below those markings...  as you want the spring tension to take place.
 If you place them too close, the spring wont even activate, or it will barely be any resistance.
 If too far apart,  it may be too tight.  Too hard to snap shut and open... if you can even get it to
close.
 Best thing to do, is to try it on scrap wood first.  Then, when you finally get the proper distancing
for the correct tension desired,  measure and copy that to your work-piece.
 You do NOT bend the spring manually!   The tension is created from the proper spacing.
 Look at the side of the thing.  There is a slide that allows the spring to travel
backwards as its being clamped.  You can get a good idea of the springs
travel distance from looking at that.
rdowdy95
  • This is my rifle.
« Reply #6 on: April 02, 2007, 01:46:29 pm »
Cool guys.  I will try this when i am totally done wiring the panel.  So 3mm below the initial traced screw holes.  Seems easy enough.  Will definately test on scrap wood first.
