Author Topic: TVs and UAII  (Read 1432 times)
gcounterman
  • Last login:March 31, 2007, 07:05:51 pm
TVs and UAII
« on: March 29, 2007, 02:26:10 am »
I was wondering if anyone here has put a UAII kit together with a TV in it and what the steps were to securing it there.
I'm not sure if its as simple as just putting the TV into the cabinet and voila or if extra bracing is needed ect.
Also any insight as to what size TVs would work well in it would be helpful.  I've been looking in the 20-27" range but I'm a little worried about the weight of a 27" in the cabinet.
Any input would be greatly appreciated.
« Last Edit: March 29, 2007, 02:28:14 am by gcounterman »
richms
  • Last login:January 07, 2025, 06:42:57 pm
  • s92a sucks
    • richms.com
Re: TVs and UAII
« Reply #1 on: March 29, 2007, 09:46:15 am »
The only difference between a 27" tv and arcade monitor is a few kilograms of plastic. 90% of the weight is in the tube.
To mount it, search on here for decasing, thats going to get you a bare tube, which you can mount into a frame off an arcade monitor, or else you will have to add a shel perpendicular to the monitor surround, and put a block on it to stop the tv moving, and then a cargo strap or similar to hold it in there securely against the block.
