Author Topic: Is there a difference between server memory and pc memory?  (Read 1215 times)
gonzo90017
« on: March 27, 2007, 12:27:34 pm »
Will memory pulled from a server work on a pc? It's PC100 just like my pc.
SavannahLion
Re: Is there a difference between server memory and pc memory?
« Reply #1 on: March 27, 2007, 12:36:34 pm »
In theory, it should work fine. In practice, it depends.
Try it and find out.
If the server was a high reliability design, you might have to contend with registered RAM and/or ECC. I'm reasonably certain you can't mix and match. It's one of those things I know there's a perfectly good reason why, I just can't remember off hand.
Then you get into latency issues. Google around for a bit if you encounter latency mismatching.
gonzo90017
