Author Topic: best way to take apart buttons ? microswitch disassembly  (Read 6993 times)
mrclean
    • Guscade
« on: March 25, 2007, 07:49:48 pm »
whats the way proper way to take my microswitch off my button it seems stuck I dont want to force it
2,370,650 Gun.Smoke
am_monkee
  • Last login:April 29, 2009, 09:48:45 am
Re: best way to take apart buttons ? microswitch disassembly
« Reply #1 on: March 25, 2007, 08:07:38 pm »
I usually just open it up where it's connected on the lower part and then just push up. I don't know if this is going to help, as it's hard to explain in writing. The switch is connected in two places. It seems stuck b/c it's secure, but you just need to pry it a little and it'll pop out. Hope that helps.
modessitt
  • Last login:October 17, 2021, 07:02:28 pm
  • Technician
« Reply #2 on: March 25, 2007, 08:45:16 pm »
I had a button the other day I couldn't get the microswitch to come out of.  Turned out to have a little screw through the side that held the switch in place.  Look for that before you force it and break it.
BTW... when trying to figure out something on a generic part like this, try posting a pic of what you're working with so we can see if we're familiar with it.
Working Games:Joust CT,Gyruss UR,Pong,Battlezone UR#1
Current Proj's:Battlezone UR#2
Cheap/Free Cabs Wanted: DK,KarateChamp,Shinobi,Ghosts&Goblins,CircusCharlie,10ydFight,PolePositnCP,RallyX,Frogger
shorthair
« Reply #3 on: March 25, 2007, 09:44:43 pm »
Your standard cherry microswitch on a standard Happ button is held by two pins, on arms connected to the button on one side. (There's a two-pronged retainer on the other side.) Pry lightly on the lower (or, if it's upside-down, upper) arm, then push up.  (This is merely a more-detailed description that am_m was trying to explain.) Do the same with the other arm pin. Fini.
« Last Edit: March 25, 2007, 10:40:23 pm by shorthair »
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #4 on: March 26, 2007, 09:55:36 am »
Usually, you just push the switch so the TOP arm is no longer holding it, then swivel the switch upward on the lower arm until it's free to pull out.
NO MORE!!
shardian
« Reply #5 on: March 26, 2007, 10:03:30 am »
Ultimate pushbuttons (the ones that have the microswitch on its side) have a screw that needs to be removed. Here is an exploded view.
If your button is a typical happ pushbutton, you just pry a little on the top holder piece and pop the plastic bump out of the switch. Then rotate and pop out the switch from the bottom bump
