Author Topic: Happ USB Trackball - bad optical encoder - second time  (Read 1160 times)
fiscap
  • Last login:November 24, 2024, 03:30:36 pm
  • I dare ye enter... the dungeons of daggorath!!!
    • BYOAC blog
« on: March 25, 2007, 08:40:50 am »
I'm wondering if I'm the only one out there with Happ USB Trackball problems or if there are others with my similar problem. This is the second time in less than a year that the y-axis on my 3" Happ's USB Trackball has quit on me. This happened last April and I had to replace the PCB (A) Encoder Board. It's worked fine for the last eleven months and just quit again on me the other day.
Here is a picture for reference -
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Re: Happ USB Trackball - bad optical encoder - second time
« Reply #1 on: March 26, 2007, 07:15:06 pm »
A couple others here have had problems.  I don't think the problem is very common, as it seems that these USB versions are the most popular purchased ATM.
Personally, I like getting the arcade version + mouse interface, but it might be because they were twice as cheap as the all-in-one's when I bought mine.  ;)  Anyway, if one sensor board goes down, I just pay to replace one sensor board, not sensor + interface.
Robin
Knowledge is Power
fiscap
    • BYOAC blog
« Reply #2 on: March 29, 2007, 01:09:52 pm »
Thanks for the reply rebelscum. In my particular case, the PCB (A) Encoder Board is the optical sensor and USB interface together so I have no choice but the replace the whole assembly. I haven't done any circuit testing yet, but I'm pretty sure that the IR optics are burnt out on the board since the 'x-axis' which plugs into this board still works fine.
boboli
  • Last login:March 22, 2013, 04:03:29 pm
« Reply #3 on: April 09, 2007, 12:53:57 am »
I just started having the same problem - mine is only 2 months old!
Is there some kind of warranty on these things? I bought through one of the resellers on this board. Haven't discussed with him yet.
