Author Topic: A new skin from LHUPATECH: "SCANLOG III LHF 1 FESTIVAL"  (Read 4518 times)
LHUPA
  • Last login:September 03, 2019, 01:05:09 am
« on: March 25, 2007, 03:46:31 am »
This is a new skin from LHUPATECH: "SCANLOG III LHF 1 FESTIVAL" inspired from the
80's NSM's jukebox "Festival ES 160 (1978-83)" - Also can be "ES-2 (1984)". The particular characteristic of this model to look like a dashboard, has made the inspiration to build this skin! You can download the 1.6 MB file at savefile.com or
directly from this link!
http://www.savefile.com/files/577218
This skin will also available in the "LHUPATEC's SKIN CATALOGUE DOWNLOAD CENTER"
http://forum.arcadecontrols.com/index.php?topic=62333.0
For best results, I recommand to use the .ini files jukebox and control especially adjusted
for this skin! You can download it here!
.INI FILES for "SCANLOG III LHF 1 FESTIVAL" Skin :   http://www.savefile.com/files/577393
Good lock!
LHUPA
« Last Edit: March 25, 2007, 05:50:38 am by LHUPA »
Johnny
  • Last login:February 09, 2026, 03:11:19 pm
  • I Want My Own Coctail Cabinet!!
Re: A new skin from LHUPATECH: "SCANLOG III LHF 1 FESTIVAL"
« Reply #1 on: March 29, 2007, 12:31:10 pm »
I have tried this one, and it looking great.
So far I have one problem, The zero ("00") selection does not work.
As of this all the other selections is one up. eg to select song 28, I have to push 29.
I can't find any problems with the ini (or skn) files, but then again I might be blind.  :-[
I'm using the ini files that comes with this skin.
Johnny Andersen
 Oslo - Norway
LHUPA
« Reply #2 on: April 02, 2007, 12:39:46 am »
Dear Johnny,
Thank you very much for signaling this problem! I will take it in consideration as soon as possible.
Problems: - The "00" selection does not work!
                 - Erronous selector
Once these problems repaired, I will replace this one for the repaired one in few days! If you encounter other troubles with all other LHUPATECH skins, please notify me in order to debug any problems!
Thank You!
LHUPA
