Author Topic: T molding question?  (Read 5154 times)
Kronos
  • Last login:January 11, 2025, 02:00:32 pm
T molding question?
« on: March 20, 2007, 05:50:37 pm »
going to start a new bartop project.. I have a ? about slot cutters.. what size should I but for use with 5/8 mdf..
spacies
Re: T molding question?
« Reply #1 on: March 20, 2007, 06:14:26 pm »
Depends on the width of the locking fins, or fir tree (technical name) on the t-molding you are going to use.
Have a look at www.tmolding.com .
Below each picture they have the size slot that needs to be cut.
Kronos
« Reply #2 on: March 20, 2007, 07:04:52 pm »
ok.. I don't know that I have ever seen a 5/64th slot cutting blade... I do have a 1/16 slot cutting blade... Should I use 1/2 mdf for this or go with the thinker 3/4
ScottS
  • Last login:November 01, 2007, 02:21:30 pm
« Reply #3 on: March 20, 2007, 08:12:00 pm »
t-molding.com will be happy to sell you a 5/64" slot cutter in addition to any T-molding you happen to need. Your 1/16th inch cutter will be way to tight for molding that requires a 5/64" slot.
Personally, I wouldn't use 1/2" MDF for anything. Then again, I wouldn't use MDF for anything. In my area, 5/8th inch material is hard to come by so my tendency would be to use 3/4". My stock suggestion is to use plywood or MDO in preference to MDF.
« Reply #4 on: March 20, 2007, 09:51:58 pm »
I don't often disagree with Scott - but in this case I do.
I'd wager a 1/16" slot cutter will work fine for a 5/64" T-mold. It's only a 1/64" difference between the two. In fact, much of this t-molding calls for a 3/32" and it's recommended to use a 1/16" to get a tight fit.
Kronos
« Reply #5 on: March 20, 2007, 10:57:29 pm »
I like the wait of 5/8 MDF.. I would like to try MDO but nobody sells that around me... and dont know if 5/8 ply will hold a good slot?
Thanks for theinfo Lew and scott.. I think I will try it with 5/8 and a 1/16 slot cutter.
Kaytrim
  • I'm too nice a guy
« Reply #6 on: March 21, 2007, 11:54:09 am »
I suggest that you use 3/4" MDF for the sides and 1/2" for the CP with 1/4" plexi.  That way you can get the best selection for your t-molding.
TTFN :cheers:
Kaytrim
NiteWalker
  • Last login:April 25, 2022, 07:33:24 pm
  • Routers can do anything.
    • SimpleCase Custom Arcade Stick Enclosures
« Reply #7 on: March 21, 2007, 04:15:23 pm »
I had to go to a lumberyard for 5/8" MDF but it's what I use for control panels now. Works great. As for the slot cutter, if your intentions are to use 5/8" MDF and 1/8" plexi for the overlay then you'll need 3/4" t-molding, which uses a 1/16" slot cutter. The fit is very tight and works good. If you try to use a 1/16" cutter with t-molding that requires a 5/64" slot, the MDF will likely split when you try to insert the t-molding.
How come you don't like MDF Scott? It's not like it's particle board... ;)
It's 9am. I'm calling it a nite.
ScottS
« Reply #8 on: March 21, 2007, 06:50:04 pm »
Right: it's actually worse than particle board! ;D
There are a number of things I dislike about MDF: it's extremely heavy and not especially rigid, it doesn't hold screws particularly well, it sucks up paint and wood glue like a sponge, it probably contains more toxic formaldehyde than PB or plywood. On the plus side, it's dirt cheap. And you can route complex profiles for non-structural applications. Cabinet doors and fireplace surrounds/mantels often take advantage of this; MAME cabinets not so much. Given that there are better materials out there, I don't see any reason to fool around with MDF...
« Reply #9 on: March 21, 2007, 07:56:33 pm »
Theres your answer for why most people are using MDF.
