Author Topic: The new mame screenshots rules  (Read 3515 times)
Jayme65
  • Last login:February 13, 2018, 01:57:12 am
« on: March 17, 2007, 10:25:45 am »
It appears that mame saves now screenshots in a folder named by the rom's name. So I would have 2 questions about it if you please:
- Which frontend uses this function?
- Is there an utility to transform your "old" screenshot folder into the new format?
Thanks very much,
Jayme65
Re: The new mame screenshots rules
« Reply #1 on: March 19, 2007, 04:39:36 am »
Anyone please?
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
« Reply #2 on: March 19, 2007, 06:02:18 am »
Mame saves screenshot by pressing F12 in a folder since a while.
Almost all front end are able to manage that.
Or may be i miss your point.  What is new?
Jayme65
« Reply #3 on: March 19, 2007, 06:47:38 am »
No, this is the question ;-)
Sorry but I didn't change of mame version for a longtime and didn't know every frontend now use that scheme.
Do they allow both situation (all screenshots in one main folder OR each screenshot in its own folder)...or only the new one?
Is there an utility to chnage my "old"screnshot folder into a "new" one (I mean with all screenshots moved to their respective folder)?
Thanks  very much,
youki
    • Atomic Front End
« Reply #4 on: March 19, 2007, 06:57:16 am »
oups sorry,
You mean that mame now create a folder by game and put screenshot inside?
I'm not sure that FE manages that in standard.   But in case of mine AtomicFe , i could do a plugin to manage that.  Or may be simply add an option in the FE.  I will check that.
Jayme65
« Reply #5 on: March 19, 2007, 07:03:51 am »
Yep, that's what I mean ;-)
It seams that this change has been implemented since v.110
But not so many frontend take it in account, aren't they?
Perhaps not very useful if you get your whole screenshot set from the outside...but once you have to do a screenshot by yourself, the screenshot would be saved in your screenshot folder within a new folder...in which the frontend won't read in.
youki
    • Atomic Front End
« Reply #6 on: March 19, 2007, 08:59:51 am »
I'm going to support that in AtomicFe in the next version.
I don't know for other FE , may be Mala or GameEX supports that already , If Loadman or Swinduw read this thread  they could confirn or no.
NOP
  • Last login:September 19, 2017, 08:22:27 pm
  • I stole my avatar.
    • winterMAME
« Reply #7 on: March 19, 2007, 11:14:18 am »
Thanks very much,
I wrote a program that does what you're asking, I think.
It was written to prep screenshots for the xbox, but I believe it'll do what you're asking for.  Does the screenshot get renamed when it's inside the folder?
on the xbox, screenshots are set up like this:
d:\emulator\screenshots\[NAME OF ROM]\0001.png
d:\emulator\screenshots\[NAME OF ROM]\0002.png
d:\emulator\screenshots\[NAME OF ROM]\0003.png
etc.
This allows the emulator to look in 1 folder and cycle through all the screenshots.
The program is here:
http://xbox.nugnugnug.com/index.php?name=UpDownload&req=viewdownloaddetails&lid=97
There are other renaming tools there as well in case this one doesn't work for you, or you don't do DOS.
The program will do the following steps:
1) locate a romname.zip filename
2) see if there is a .png file with the same filename
3) if both exist, it'll create a folder with the same name as the filename
4) move the .png file into that folder
The ROMs are only needed to match up screenshots to ROM names.  They aren't modified, deleted or touched in any way.
You can override the filename that it gets renamed to, but I don't have an option to not rename the file at all.  (I could easily add this if you need it)
-jeff!
  • Last login:January 17, 2026, 03:40:02 pm
« Reply #8 on: March 21, 2007, 03:09:58 am »
That is an interesting turn of events..... I don't think I like it though... not that I liked it when they changed it before (for a while now, it had been the first snap taken was romname.png and any additional snaps were romname01.png ect.. or something like that).
The only way I could see this new storage method being useful is if you could take a series of pngs as raw frames are very efficient for video playback on a 3d surface.
youki
    • Atomic Front End
« Reply #9 on: March 21, 2007, 04:26:55 am »
The FE can do a "Slide Show" of all snap stored for a given rom instead of displaying only one Snap.
Can be a good alternative for whom don't want or can't use the Circo's Emumovies pack.
loadman
    • MaLa
« Reply #10 on: March 21, 2007, 04:47:49 am »
Not yet with MaLa ;)
You can do this with MaLa already. There is a checkbox to search in subfolders
youki
    • Atomic Front End
« Reply #11 on: March 21, 2007, 05:52:10 am »
 ???   i don't understand here.... No for the first  ,  Yes for the second... but for me it was the same thing.      If Mala can do the second, it means it support the first.
loadman
    • MaLa
« Reply #12 on: March 21, 2007, 06:17:08 am »
Sorry I didn't read your post properly.  :(
I was refering to a screensaver for the second, where you can have Circo's Videos or Snaps(or any pics)  in subfolders as a screensaver   ;)
