Author Topic: can't get mamewah to generate list for daphne. Update: FIXED!!!!  (Read 1502 times)
lordtodd75
  • Last login:July 21, 2020, 01:42:37 am
  • I especially hate punks!
I am running mamewah v1.62b13 and daphne 1.0 and I cannot get mamewah to generate a list of games. Here is my daphne.ini file:
### daphne.ini (mamewah v1.62) ###
emulator_title                            Daphne
### List Generation Settings ###
rom_path                                  c:\daphne\framefile
rom_extension                             txt
dat_file
nms_file                                  c:\daphne\daphne.nms
catver_ini_file
list_generation_method                    rom_folder
### Execution Settings ###
pre_emulator_app_commandlines
emulator_commandline                      c:\daphne\daphne.exe [name] vldp -framefile "C:\daphne\framefile\[name].txt" -fullscreen{nodosbox}{nosafelaunch}
post_emulator_app_commandlines
general_app_commandlines
### Artwork Settings ###
artwork_image_paths
movie_preview_path
movie_artwork_no                          1
enable_fuzzy_search                       0
history_dat_file                          auto
history_dat_artwork_no                    2
### Screen-Saver Settings ###
enable_music_in_screensaver               0
select_random_game                        0
saver_type
movie_path
movie_fullscreen                          1
quit_delay                                30
saver_commandline
### Additional Settings ###
music_path
lcd_display_file_path
description_display                       [description]{scroll}
### Settings used by MAMEWAH ###
current_list                              0
I had this running before with older versions of mamewah and
daphne. All of the paths are absolutely correct. Any suggestions?
« Last Edit: March 15, 2007, 08:52:42 am by lordtodd75 »
lordtodd75
Re: can't get mamewah to generate list for daphne.
« Reply #1 on: March 15, 2007, 08:51:51 am »
I found the answer I needed in the mameworld forums. Since nobody answered my post I am assuming nobody ran into this problem. There is a glitch in mamewah v1.62b13 that prevents you from generating a list for non mame emulators. Here is the post at the mameworld forums if you want to read it: http://www.mameworld.info/ubbthreads/showthreaded.php?Cat=&Number=99454&page=0&view=expanded&sb=5&o=&fpart=1&vc=1
I also attached the mamewah v1.62b13a executable that fixes the problem. You only need to overwrite your old mamewah executable with this and you will be able to generate a list.
topher0002
  • Last login:November 09, 2023, 04:26:18 pm
  • "I'm constantly confused"
Re: can't get mamewah to generate list for daphne. Update: FIXED!!!!
« Reply #2 on: August 31, 2007, 01:15:10 pm »
I had the same problem with other emu's and couldnt find a darn thing on it until i found this,  I spent about 3 hours driving myself crazy because I knew i had everything set up right,  THANK YOU FOR POSTING THIS and the ZIP FILE!!!!  Mine works great now  =)
"True Knowledge consists in knowing that you know nothing"
