Author Topic: Where to find 'cap kits' - Dotronix RSV25?  (Read 2768 times)
ahofle
    • Arcade Ambience Project
« on: March 14, 2007, 12:16:57 am »
I have a rather non standard arcade monitor, a Dotronix RSV25.  It has quite a few years of usage (it was made in 1994 I believe) and exhibits some of the symptoms of bad caps people around here have reported.  I checked Bob Roberts, but of course my monitor isn't listed.  Is my only option figuring out the capacitance on every single cap and buying them at some place like mouser.com?
FrizzleFried
    • Idaho Garagecade
Re: Where to find 'cap kits' - Dotronix RSV25?
« Reply #1 on: March 14, 2007, 12:35:11 am »
Check with Zanen Electronics: 888-449-2636 or 806-793-6337
ahofle
« Reply #2 on: March 14, 2007, 01:32:52 am »
Will do, thx.
Organic Jerk
  • Last login:May 09, 2013, 12:39:09 am
  • I'm per pixel lit.
    • OmeshPersaud.com
« Reply #3 on: March 14, 2007, 06:21:44 am »
....so what is a cap kit?...  What should I be looking for to know that a screen would need new caps?..
what are caps?  :dunno
Guess I'm going data digging again...
Progress Rate:  Moderate      ||      Threads:  Cabinet  |  Art  |  MaLa Layout
XBL: OrganicJerk  |  PSN: OrganicJerk
FrizzleFried
    • Idaho Garagecade
« Reply #4 on: March 14, 2007, 10:08:34 am »
CAPS are a "CAPACITORS".  A CAP KIT is simply a group of capacitors for an individual board (chassis).  Instead of having to purchase each capacitor individually,  folks put together a group of these capacitors for each board and sell them as kits.  Sometimes other things (like a transformer, width coil, etc) is also included.
Electrolytic Capacitors (the round "tube" looking things on a chassic/pcb) are filled with a liquid that dries up (or worse,  leaks out) over time.  When you replace these capacitors,  it rectifies many issues with a monitor...such as color issues,  geometry issues,  "squeezed screen" issues,  sometimes it rectifies waves, etc.   Being that most arcade monitors are 20 years+ old,  it is always a good idea to replace the capacitors.   Most kits run $5 - $15 so they are inexpensive.   If you have never soldered on a component level before,  the task may seem daunting.  Prior to doing my first Cap Kit,  I was in the same boat...but it is fairly easy to do ...a lot easier than I thought it would be.
Make sure you read up on (A) How to discharge a monitor tube...this is THE MOST IMPORTANT thing you READ and RE-READ and RE-RE-RE-READ about...it can kill you if you don't do it properly...if you do it properly,  the whole process is about as anti-climatic as you can get.  (B) Read up how to DE-SOLDER.  There is two things you can really use to de-solder...a solder wick (my preference) and a desoldering gun (essentially a little mini vacuum pen thing that sucks the solder up after you heat it up).
My first chassis took me 3 hours to complete.  The second one (same G07 type board) took me about 1/2 as long.  The 3rd board I did in about 45 minutes (though there WERE less caps)...
Good luck.
Ken Layton
  • Guru
  • Technician
« Reply #5 on: March 14, 2007, 10:59:35 am »
This gets asked alot so that's why there's a FAQ at the very top of this forum. It is strongly suggested to start there.
ahofle
« Reply #6 on: March 14, 2007, 03:01:47 pm »
Well they weren't familiar with Dotronix either.  I think this monitor was really more used as a presentation/display monitor than for arcade games.  He suggested he could put together a basic cap assortment that should pretty much cover everything for $30.  The alternative is to write down all the cap values I need.  How much would a TV repair shop charge to do this typically?  Anyone live near Colorado Springs that feels like helping out a monitor newbie?  ;D
Ken Layton
  • Guru
  • Technician
« Reply #7 on: March 14, 2007, 05:48:29 pm »
I've been working on commercial arcade monitors for 30 years and I've never heard of Dotronix.
Organic Jerk
    • OmeshPersaud.com
« Reply #8 on: March 14, 2007, 06:46:18 pm »
Well yeah it's not an arcade monitor, but a presentation monitor.  It seems to be primarily used for multiple screen setups, with 10 or more used at a time..
ahofle
« Reply #9 on: March 14, 2007, 06:52:48 pm »
Well, by arcade monitor I mean a 15Khz CGA monitor that accepts RGB input.
flextechs
  • Last login:April 30, 2016, 09:50:27 am
« Reply #10 on: October 29, 2007, 02:17:11 pm »
I know this is quite old, but did get this resolved.  Dotronix is 3 blocks from me and I maintain their network server environment.
ahofle
« Reply #11 on: October 29, 2007, 03:26:07 pm »
I never did cap that monitor.  For a few other reasons, I went with a new multisync betson monitor instead of the CGA only Dotronix.
