Author Topic: WG 19K4601 problem  (Read 2170 times)
fa001
  • Last login:November 14, 2023, 11:17:08 am
WG 19K4601 problem
« on: March 12, 2007, 08:35:52 pm »
I am getting a blank screen. There is an initial light and the neck glows but I can not get any image on the screen.  I can not find a schemetics for the 4601 only later models. I tried to follow Randy Fromm's flowchart but it deadends at "Is the CRT heater glowing?"
Any help?
SirPeale
  • Green Mountain Man
Re: WG 19K4601 problem
« Reply #1 on: March 12, 2007, 11:07:22 pm »
When you turn the screen control up, does the screen get whiter?
fa001
« Reply #2 on: March 13, 2007, 12:06:27 am »
No, the screen control makes no difference.  :cry:
Ken Layton
  • Guru
  • Technician
« Reply #3 on: March 13, 2007, 12:42:38 am »
Have you capkitted it yet?
Could be that simple.
It's also likely that the "black level" pot (a.k.a. brightness) on the video interface board is shot (hairline break internally). If you buy your capkit from Zanen Electronics, it includes a new black level pot.
fa001
« Reply #4 on: March 16, 2007, 02:41:19 pm »
OK, I will operate. Cap kit on order and when I do that I will also reflow the solder joints. That should be a step forward.
But I do have one simple question, when I am testing the monitor for basic function should I be able to adjust the screen control to get a raster image or white screen without any game signal applied? Or does the monitor require a signal to light up at all.  :dunno
grantspain
« Reply #5 on: March 17, 2007, 05:47:42 am »
all analogue type monitors should display a raster without signal applied and the correct amount of adjustment on the screen volts.
i have had faults like yours but only on later monitors and i don't think it would apply to your monitor.
you seem to have the same fault as the other wg4000 thread which means this must be a reasonably common problem but i cannot say for sure as the last time i worked on this type chassis was in the mid 1980's.
do your screen flash when you disconnect power?
fa001
« Reply #6 on: March 17, 2007, 03:03:05 pm »
Well, now I have set it aside waiting for the cap kit.  I remember that I did get a light flash when it was turned on but do not remember if I got one when it was powered off.
