Author Topic: Having numerous problems with MAME programs  (Read 1627 times)
Doom bucket
  • Last login:July 07, 2009, 11:50:26 pm
« on: March 07, 2007, 10:06:44 pm »
First off...
I've been trying to use Mala as a front end for the command line mame. But really, it's just frustrating to use. I can't get any layouts working properly, and because it's command line I can't seem to get addons like kaillera working properly. I was tuned into a program called winkawaks, which seemed to do everything I wanted to do very well.
But every time I try to go fullscreen with it, it crashes. Still, it's the only program that I've used so far that actually plays the Neo Geo roms correctly. Also, I haven't managed to configure my controls properly because the program has a wierd glitch... every time I try to redfine the keys, the entire setup changes. Like I'll change one of the buttons, and another button changes in response. It's very frustrating.
I also can't seem to get my 360 controller working with any of the MAME programs. I was hoping to use it as a third player for when friends come over, but I can't even configure it. Any ideas?
SGT
  • Last login:May 31, 2025, 10:10:32 pm
Re: Having numerous problems with MAME programs
« Reply #1 on: March 07, 2007, 10:23:04 pm »
Mala is typically easy to use though there are a few quirks with the layout editor, IMHO.  There seems to have been a lot of wip and bug fixes with Mala the last 4 months, but for whatever reason there hasn't been a release since October which is frustrating.
-SGT
gonzo90017
« Reply #2 on: March 08, 2007, 07:59:39 pm »
What type of controllers are you using? USB? Make sure you don't have any turbo, or slow motion buttons pressed. Go to Start>Settings>Control Panel>Game Controllers and make sure no buttons are active. What resolution are you  using? Maybe you're using a resolution your monitor doesn't support. Try setting winkawaks to 640x480
« Last Edit: March 08, 2007, 08:02:25 pm by gonzo90017 »
Doom bucket
« Reply #3 on: March 08, 2007, 08:46:52 pm »
360 controllers are USB, yes. They don't have turbo or slow motion buttons, and none of them are "active".
Doom bucket
« Reply #4 on: March 09, 2007, 06:07:07 pm »
This is starting to get very annoying
mamewah, AtomicFE, Mala, all of them seem to have their unique problems and quirks but none of them seem to be doing what I want them to do, which is play videogames
SGT
« Reply #5 on: March 09, 2007, 08:35:53 pm »
Well if you're having problems with all software, maybe the problem is you?
J/K. For Mala problems, you need to put Mala in the subject line and then ask specific questions.  I'm sure Loadman will jump in and solve your problems as he usually does.
Speaking in general terms about problems with multiple software programs will get you little help, IMHO.
