Author Topic: ultrastik 360-ugc file for each individual game?  (Read 3853 times)
lordtodd75
  • Last login:July 21, 2020, 01:42:37 am
  • I especially hate punks!
« on: March 03, 2007, 02:37:16 pm »
I just wanted to make sure I read the ultrastik faq correctly. I need to make a separate ugc file for each of the over 5000 mame roms? If this is correct, is there a way around this or am I doomed to years of .ugc file generation?
squirrellydw
  • Last login:April 12, 2021, 11:30:22 am
Re: ultrastik 360-ugc file for each individual game?
« Reply #1 on: March 03, 2007, 02:39:52 pm »
I am not an expert but you do NOT have to make separate files for each game.  Just basic direction files.  4way 8way etc.
I b**ch. People listen!!
fatfingers
  • Got UltraStiks?™
« Reply #2 on: March 03, 2007, 05:55:27 pm »
squirrelydw is correct -- you only need basic maps.  Now, getting those maps applied automatically (so you don't have to manually apply a map before each game) is the tricky part.  I don't know what fe you use, but if it's MaLa, check out this thread for the mapper plugin I wrote.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
lordtodd75
« Reply #3 on: March 04, 2007, 10:22:28 am »
Damn, I am using mamewah. Someone please tell me that mamewah has the ability to somehow autoload the maps without me having to do hours/days of work.
Popcorrin
  • Last login:March 06, 2022, 11:11:43 am
« Reply #4 on: March 04, 2007, 11:24:04 am »
I know it's possible from mamewah.  Probably a month or so ago, minwah explained how to do it in the software forum.  If I can find the thread I'll let you know.
lordtodd75
« Reply #5 on: March 05, 2007, 08:43:34 am »
I found it!!! Thanks Popcorrin  ;D
You could do the same in Mamewah, John, and in the commandline to launch Ultramap use the [input] placeholder...something like*:
pre_emulator_app_commandlines c:\ultramap\ultramap.exe c:\ultramap\ugc\[input].ugc
(* I'm yet to use the software so might not be exact usage)
That said there is probably a slight flaw with recent Mame versions where multiple input types are held in [input], but you could get round this with some more .ugc files.
Weird thing is, I tried this suggestion and every time I booted mamewah, it would erase this entry. Oh well, I have a feeling it is because I am running 1.61, I will upgrade and try again. BTW do I need to put this in the mame.ini file or the mamewah.ini file. Anyone? Man I am so close I can taste it  ;D
lordtodd75
« Reply #6 on: March 05, 2007, 12:13:45 pm »
Alright, the upgrade to the newest version of mamewah seems to have fixed that issue. Now the final part of the problem is I can't get mamewah to recognize the ultrastik so I can scroll through the games list. I know this is as easy as setting some option  in one of the .ini files to true, but I can't find it for the life of me.
By the way where is chadtower and his obligatory "once per topic" post. Gotta keep that post count up  >:D
fatfingers
  • Got UltraStiks?™
« Reply #7 on: March 05, 2007, 12:27:54 pm »
It looks like that MameWah config should help you out for the most part.  If you're at all a fan of Q*Bert or any other 45 degree mounted game, this will not work for you because there is no [input] type of 4-way 45 degree in MAME, only 4-way.
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
QuixoteQuest
  • Last login:October 18, 2010, 07:24:11 pm
« Reply #8 on: March 05, 2007, 01:41:46 pm »
With an UltraStik you just set up a map to give the normal up/down/left/right inputs but do them on the 45-degree positions, just like a rotated 4-way would. Works great for Q-Bert and Congo Bongo. (If you need a visual, check out RetroBlast's UltraStik review and they show an example of this map.)
lordtodd75
« Reply #9 on: March 05, 2007, 02:36:47 pm »
I am pretty sure you can make a game specific .ini file, you would only need to replace [input] with qbert.ugc. This ofcourse is assuming that you named your ugc file qbert.ugc
I think you misunderstood what fatfingers was saying. It is very easy to make a qbert specific ugc file. The problem that fatfingers was referring to was loading that file from mamewah automatically if you use [input]. The reason being [input] pulls control type directly from mame and mame has qbert labelled as a "joy4way", which is a standard 4-way. Look at that, I learned things  ;D
So does anyone know how I can make mamewah recognize the ultrastik so I can scroll through my games using it.
« Last Edit: March 05, 2007, 02:46:20 pm by lordtodd75 »
fatfingers
  • Got UltraStiks?™
« Reply #10 on: March 05, 2007, 03:01:22 pm »
jcrouse seems to think he does.  Check here.
Good luck!
My DK low scores
1) 180700
2) 165000
3) 162900
4) 162600
5) 158500
lordtodd75
« Reply #11 on: March 05, 2007, 03:04:44 pm »
Thanks fatfingers, guess I should have checked the other post before I replied here  ;D No wonder I couldn't find anything in the .ini files, it is in the .cfg
